Author Topic: Increase in biofuel content in regular unleaded  (Read 2217 times)
« on: November 14, 2011, 02:34:48 PM »
I wonder whether the 126 will be able to run on the impending change in fuel mixture of regular unleaded petrol. The government is preparing (next year?) to increase biofuel content in regular unleaded fuel from five per cent ethanol, which most cars can safely use, to ten per cent. Motoring groups says that cars made before 1993 will be unable to run on this mix, forcing many drivers of older cars to buy premium or super unleaded. The cost of motoring is constantly increasing. This initiative will definitely cause the demise of many old and classic cars.
« Last Edit: November 15, 2011, 10:01:56 PM by Amateb8 »
Draigflag
  • Got a New Abarth 500 too!
Re: Increase in biofuel content in regular unleaded
« Reply #1 on: November 15, 2011, 08:13:31 PM »
Hmmmm....I'm confused. Will the 126 be ok on this stuff? Cheeky sods are apparently putting fuel up by 3p too, then another 3p in August of 2012. Nice, on a fun week i can already spend £120 on fuel somtimes...
Blonde126
« Reply #2 on: November 16, 2011, 07:52:19 PM »
This is horrible news :(
I hope it can run on it! And this is also worrying because I see plenty of cars out and about that were made pre-1993.
smallcox
« Reply #3 on: November 16, 2011, 08:21:04 PM »
Don't worry Guys, I remember when they all said a 126 will not run on unleaded when that first showed its head.
Well I only put unleaded in mine like you do to I quess, and quess what you wouldn't know the difference. Even our valve seats cope with unleaded and they said they will burn out in a few miles.
If this new fuel shows itself I will be very surprised if all internal combustion engine wont run on it.
Ps news paper are not always right
Blonde126
« Reply #4 on: November 16, 2011, 09:30:19 PM »
I've read something about the ethanol corroding the metal fuel tanks, where as modern cars have plastic ones...
But I wouldn't know, I just googled the topic to see what would come up (something from the independant about British tourists in France accidently filling up their older cars with fuel that contained 10% ethanol).
gsxr126
« Reply #5 on: November 16, 2011, 09:46:49 PM »
I agree with smallcox's sentiments. Caltex is rolling out E85 at a lot of servos here (that's 85% ethanol).
Its becoming very popular as you can make up to 100hp extra on the stuff (depending on engine size of course).
Corroding tanks???? I think people that have had issues with this may have already had a corroding tank. There are many 70's street machines running E85 in Sydney and I havent heard of any issues.
Check this one out for example:
http://smoty.com.au/comps/smoty2011/viewmachine.aspx?Code=MI3
« Reply #6 on: November 23, 2011, 10:20:26 PM »
If you have the patience to read an article re above from the Federation of British Historic Vehicles Club, click on the link below. It is actually quite interesting. There are actually pros and cons to the rise in ethanol content in regular unleaded. There may be ligitimate concerns for some owners of older cars.
http://fbhvc.co.uk/bio-fuels/
« Reply #7 on: November 24, 2011, 09:30:19 AM »
In Africa we were not afforded the luxury of proper petrol. It always had ethanol in it and was sold as 'Blend' on the pumps. We grew more sugar than we needed, and needed fuel more than sugar. Only issue was the stuff evaporated very quick! It wasn't uncommon to have to re-tune the car after filling-up as the ethanol content varied.
Sanctions coz it was a heathen colony, then sanctions coz it was run by a tyrant, who really cares about countries with no oil  :P I guess they did what they had to to keep things running.
I ran anything from a fiat500 to a landrover seriesII and an AJS model 18 and a Matchless G80CS on Blend, we had no other fuel so it was that or ornament.
Corrosion in tanks and fuel system? Huh?
If you really worried pull the tank out and do what I do with the bikes and treat the inside of the tank with that treatment from the Frost catalogue.
If anyone knows where I can lay my hands on the aircraft tank treatment stuff I would be grateful as that forms a nice white impenetrable layer in the tank. I tried it, as I was given some, on my G80CS shortly before leaving as it stood in a barn for 20 years with no cap on and was impressed with the results. ;D
gsxr126
« Reply #8 on: November 25, 2011, 06:34:35 PM »
How about this stuff
http://www.por15.com/US-STANDARD-TANK-SEALER/productinfo/TSG/
I've used it on a 61 holden fuel tank and it worked well.
fightingtorque
« Reply #9 on: December 01, 2011, 03:34:40 PM »
must admit i haven't read the article mentioned in the earlier post, but issues you may find with ethanol are:
It attracts moisture which is why there is the possibility of corrosion.  If you are concerned, regular purging of the system should resolve that.
Some rubbers are not tolerant of it, could be a problem.
For the same volume of fuel, an increased ethanol fuel needs more air to burn it.  Or put the other way around, compared to pure gasoline, a 5% ethanol mix will result in being about 2.5% lean (hardly noticeable) and a 10% ethanol mix will be about 5% lean (starts to become noticeable).
If you re-adjust your idle mixture, then the idle will be ok.  You may experience things like hesitation from cold, but once warmed up it wont be too bad.  If you want to you could re-jet the carb but this is a bit of a specialised job (not sure if all the jets are available for these carbs).
A problem is that the regs will be 'up to 10%' which means one day it could be 0 and one day could be 10%.
Overall, probably not a disaster.  Beyond E10, you will definitely need to be retuning your carb.
FT
