Author Topic: Changing the door handles and locks  (Read 2174 times)
Abiella
    • The Box Collective
« on: November 10, 2011, 06:42:13 PM »
I drive on Button Moon...
Re: Changing the door handles and locks
« Reply #1 on: November 11, 2011, 11:07:51 AM »
You can get them as a pair from 126fan.sk. I asked since i only needed one and they said they can sell them separately. I instead found one somewhere else and so in the end i had separate keys to the ignition, left and right hand doors, fuel cap and bonnet :)
Abiella
« Reply #2 on: November 11, 2011, 10:51:01 PM »
Great thanks... I'll check 126fan.sk
I have got abit of rust on my old black ones and they are fading grey so I think some nice new Chrome ones for Christmas would be nice!
Haha... so you have a very heavy set of keys!
Tate
« Reply #3 on: November 12, 2011, 09:51:59 AM »
I bougt a set of locks from 126fan.sk
Is there somewhere any guide or does somebody have experience how to change all locks to new ones?
Fiat 126 -73 project
2 x BMW E21
« Reply #4 on: November 12, 2011, 01:41:48 PM »
 :$ good luck. I removed and changed door handles, cut hands, bad language, and a lot of fiddling.
It is a pain in the A%$£.
But if I managed to do it I am sure anyone can  :D
« Reply #5 on: November 13, 2011, 05:02:08 AM »
Agree, much easier if you buy a complete door handle than just the barrels...
On the reverse side of the lock there's a pin that holds on the thingy with the ball joint on it (where the plastic rod is attached to.) I think getting that off is the hardest bit as it is made of some sort of aluminium cast and could be a bit fragile (and if the ball joint part breaks off you can't mend it). Also it has to fit tightly onto the end of the barrel: as it roates it has to provide enough lift through the plastic rod to
the latch so that the door can be locked and unlocked. One reason i had to change mine was because it was very worn around that part and no amount of fussing around helped lock it properly.
