Author Topic: 126 bis running  (Read 1664 times)
Pete 126bis
126 bis running
« on: November 08, 2011, 09:29:51 PM »
Hi i have finally got my bis up and running after sitting in the workshop  for a long time  :) but after getting it up to temp i now have found that the main bearings have gone or on there way out as it rattles / rumbles on tick over , any tips advice on replacing the bearing , so for me it was 1step forward and 2 steps back but i new that when i brought the car it had been standing and driven quite hard before it came to me but iam still smiling cheers Pete
Lina
    • Facebook profile
Re: 126 bis running
« Reply #1 on: November 09, 2011, 09:20:04 PM »
Great news you've got it running!  Sorry to hear there's now more to do - but that really seems the way with these things!!
Good luck with it!! :)
Lina - as in Lyna - as in dustbin liner, eye liner, ocean going... etc!
Re: 126 bis running
« Reply #2 on: November 09, 2011, 09:51:34 PM »
I assume then that the oil light comes on  ? If the light goes out on start up and stays off your main bearings will be OK and the rattle comes from elsewhere.
Pete 126bis
Re: 126 bis running
« Reply #3 on: November 09, 2011, 10:18:31 PM »
Hi the oil light came on with the ignition and went off when running , i do know that the previous owner did run / drive it  with NO oil in as the drain dung was sitting on the radiator cowl and had nothing in and sat for a few years  before it came into my hands , open to ideas, views etc cheers Pete
Re: 126 bis running
« Reply #4 on: November 09, 2011, 10:43:41 PM »
So if you have new oil in there and the oil light stays off when the engine is up to temperature that is a good sign. The rattle could be tappet adjustment , worn timing chain or just a loose or busted bit. Worst case would be worn little ends but that would be rare. If the engine runs OK I would check out the usual suspects and adjustments , keep an eye on the oil and see where you go from there
