Hi i finally got my engine up and running
to find that the main bearing have given up ,
so took the engine out to sort that job out and the bellhousing on the gearbox was fairly wet and had traces of oil in so further investigation found that the bearing gear shaft axle both o rings were damaged and thats the prodlem . My question is how do you replace the internal o ring behind the bush , anyone done it or have any ideas and where is the best place to get new parts from cheers Pete
