Author Topic: Fiat 126 -73 restoration [ Now: It's ALIVE...!!! :) ]  (Read 118879 times)
Tate
Re: Fiat 126 -73 restoration [Now: Everything]
« Reply #165 on: April 21, 2013, 07:46:51 PM »
Fiat 126 -73 project
2 x BMW E21
pietschokkenbroek
« Reply #166 on: April 21, 2013, 08:45:35 PM »
 :good: Makes my happy, looking at it  :D
Landy-Pilot
« Reply #167 on: April 22, 2013, 09:39:58 AM »
That paint job looks sweeeeet!!
fixit
« Reply #168 on: April 22, 2013, 06:16:19 PM »
have you body sanded the paint?
 paint job looks brilliant
quick quick lock the shine in with polish (of your choice) for the ultimate wet look
 ;D ;D ;D
Tate
« Reply #169 on: April 22, 2013, 06:55:09 PM »
Thank you guys!
I have to shock you and confess that the paint is actually intended for heady-duty equipment. Therefore it has only 90% (at it's best) shine if you compare it to a car paint. This was my choice and I hope that it will be more stronger than basic car paint.
2 x BMW E21
Tate
« Reply #170 on: April 29, 2013, 05:33:27 AM »
Fu**ing stud bolts..  :cry: This already happened earlier but now I got it finished. Those front leaf spring bolts started to spin. I should have removed them already before painting the car but I was lazy :$
This was so stuck that I couldn't remove it
Fire in the hole!
Then I made 2 x this
Welded them
2-component epoxy primer
surface coat
« Last Edit: April 29, 2013, 05:51:37 AM by Tate »
2 x BMW E21
Tate
« Reply #171 on: April 29, 2013, 05:43:34 AM »
Front wheel hub threads had taken some damage so I decided to drill the threads open and install stud bolts.
New horn
New gas tank + level sensor
Steering gear fully overhauled with new gaskets and oil
2 x BMW E21
Landy-Pilot
« Reply #172 on: April 29, 2013, 09:58:02 AM »
Looks like you've had a busy weekend!! Good Work
Fiatos
    • Photoalbum
« Reply #173 on: April 29, 2013, 08:33:09 PM »
Oh, you've welded the new stud bolts!
It's easy to renew the bolts when drill a hole from the interior. Then you must not weld and in future it's easy to renew it.
Tate
« Reply #174 on: May 04, 2013, 08:41:15 PM »
New rubber sealings
New steering column switch from forum user "midvillesb"
Parcel shelf cover cleaned and washed
High end hifi system waiting for installing.. (already installed but I have no pics yet)
New front suspension parts painted
Same here
Rod ends for front suspension arms
Same with rubber covers
My another 126 from 1975 has proven to be valuable in donating parts.. ;D
« Last Edit: May 04, 2013, 08:55:14 PM by Tate »
2 x BMW E21
Tate
« Reply #175 on: May 14, 2013, 05:53:16 AM »
Brake disc adapters with new steering knuckles
Testing how they fit together
Waiting for new springs
Engine has still a lot to do
In case you get thirsty while driving this beast...  ;D (windscreen washer fluid tank)
And last picture is the cherry on the top of this cake.... my new daily driver  :P Peugeot 205 1.4 Green with sunroof, central locking, electric windows, Gutmann 13" alloys etc  8)
« Last Edit: May 14, 2013, 05:56:04 AM by Tate »
2 x BMW E21
kev126
  • Built not bought
« Reply #176 on: May 14, 2013, 11:55:35 AM »
Great work so far! Cool 205 :)
1989 Fiat 126 BIS
Tate
« Reply #177 on: May 18, 2013, 05:42:12 AM »
New custom made stainless steel braided brake hoses with anti-acid fittings
Intake manifold parts
I had to make the intake hole slightly bigger
2 x BMW E21
Tate
« Reply #178 on: May 19, 2013, 06:08:07 AM »
New custom made rear shocks finally came from GAZ. Damn they are nice...!  ;D  :P
New orginal KYB rear vs. GAZ
2 x BMW E21
« Reply #179 on: May 19, 2013, 07:56:53 AM »
 Amazing.This is just getting better and better 8)
