Author Topic: Fiat 126 -73 restoration [ Now: It's ALIVE...!!! :) ]  (Read 118879 times)
Tate
Re: Fiat 126 -73 restoration [Now: Engine]
« Reply #150 on: March 08, 2013, 02:59:05 PM »
Long waited goods from GAZ UK  :santa:
Fiat 126 -73 project
2 x BMW E21
Tate
« Reply #151 on: March 25, 2013, 08:20:01 PM »
Sleeve for intake manifold
Sleeves for front A-arms
Tripod conversion
Microsquirt ECU + harness
VAG ignition coil
2 x BMW E21
Tate
« Reply #152 on: April 01, 2013, 07:00:26 PM »
Easter.. good time to work with cars  ;)
Pedal assembly needed some love...
...so I gave love.
Painted some other parts also
Installed new bearings to rear hubs
New brakes to rear
This is how I left the car for now
2 x BMW E21
pietschokkenbroek
« Reply #153 on: April 01, 2013, 07:14:01 PM »
 :thumbup Good progress, you make me jealous  :D
Landy-Pilot
« Reply #154 on: April 02, 2013, 12:27:39 AM »
Great restoration, inspired me to make a proper start on my 1980 deville. All your pictures provide excellent reference material.
Keep up the good work, look forward to more!!!
Regards Phil
Tate
« Reply #155 on: April 03, 2013, 06:02:58 PM »
Thanks guys! One medium setback came up with rear shocks. I bought new KYB shocks from 126FAN but they are too long to use with 17cm sport springs. So... once again I have to order shocks made by my wishes from GAZ UK...   :-X That means £££££ :$
2 x BMW E21
« Reply #156 on: April 03, 2013, 06:42:22 PM »
Hi Tate, Have you thought of extending the top mount to stop the spring falling out, I don't know if its posible to shorten and re-thread the top bar? I bought some lower rear sport springs and the gap with standard sockers is around 25mm, the spring just falls out when the car is jacked up :( so iv'e not fitted them yet.
P.S. Stop sending your crap weather over to the U.K. we want summer to start ;D
« Reply #157 on: April 03, 2013, 07:27:35 PM »
Hi if you slacken the anchorage bolts for the swing arm, lower the car down and re-tighten when the car is on the ground the rubber inserts in the anchorage bushes, if in good condition, will keep the swing arm up and the springs in place.  It is an awkward job to do in the drive.
Tate
« Reply #158 on: April 03, 2013, 07:52:36 PM »
Hi Pete, It would be possible but in my opinion the right way to do this is to fit a shorter shock. GAZ can manufacture shocks with stem/stem mounts, adjustable damping and with desired open/closed length. That sounds perfect but it will cost some money. On the other hand the "old rule" says that if you wan't good handling and chassis for your car, you should invest in shocks.
Ps.. I'm so sorry for the weather  :D
2 x BMW E21
Tate
« Reply #159 on: April 03, 2013, 07:58:00 PM »
Hi! That could work but I don't wan't to take the risk if in some situation the spring gets loose while rebounding.. In worst case scenario that could lead to fatal consequences   :headscratch:
2 x BMW E21
« Reply #160 on: April 04, 2013, 07:54:20 AM »
 You can buy shorter shocks on the internet.
 http://www.500mania.it/ns/index.php/store_gbr/prodotti/suspensions-and-brakes/shock-absorbers.html
 or you can try eBay Italy, you probably find them even cheaper.
Tate
« Reply #161 on: April 09, 2013, 05:39:55 AM »
Shocks sorted out...
Cylinder head fully overhauled with few tricks  8)
Something new for the front axle..
2 x BMW E21
Landy-Pilot
« Reply #162 on: April 19, 2013, 10:34:03 AM »
Tate we need an update its been 10 days!!
pietschokkenbroek
Re: Fiat 126 -73 restoration [Now: Everything]
« Reply #163 on: April 19, 2013, 05:02:30 PM »
LOL  :D
Tate
« Reply #164 on: April 19, 2013, 08:07:58 PM »
Hou-hou-hou..  ;D I've been very busy with the car.  :$ Every day after work I've been building this car and at the same time keeping in mind that I wan't this to be ready-to-drive in near future.
I have faced a couple of big setbacks.. front shocks which I ordered from GAZ were too long, so I had to send them back to UK and they will shorten them. Front wheel 4x98 wheel hub threads have taken some damage so I have to think some solution for it.
I have been very lazy taking new pictures but here are two new ones:
New brake master cylinder:
Then I gave a full refurbish for the front brake calipers: cleaning&paint and new sealings
2 x BMW E21
