Author Topic: Locking Alloy Wheel Nuts Bolts for Fiat 126 Bis  (Read 2149 times)
« on: October 16, 2011, 12:24:00 AM »
I am unsure whether this topic come up before. I am looking for the above for a 126 bis. I may have found one on ebay BUT it is for a Cinquecento. Will this also fit a 126 Bis? Here is the link
http://www.ebay.co.uk/itm/110751633060?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Re: Locking Alloy Wheel Nuts Bolts for Fiat 126 Bis
« Reply #1 on: October 16, 2011, 08:14:35 AM »
Thread pitch 1.25 is finer on the cinqe , you need M12 x 1.5 and preferably about 5mms longer than the standard bolts  :)
Eklipze3k
« Reply #2 on: October 16, 2011, 09:50:19 AM »
This might be a stupid question rusty, but why would you want them any longer? If the shank length is the same as standard it'll be the same depth into the hub (which should be the right amount), any longer and it risks fouling the brake shoes surely?
« Reply #3 on: October 16, 2011, 10:44:22 AM »
Many thanks. M12 x 1.5 it is. I had my yellow Bis re-undersealed Friday (previous owner had it undersealed almost a decade ago) and found out for the first time that my rear wheel alloys have spacers. I think the additional length for the rear wheels with spacers will come in handy. Next question, where do I buy them?
« Last Edit: October 16, 2011, 09:42:45 PM by Amateb8 »
« Reply #4 on: October 16, 2011, 12:10:32 PM »
Not a stupid question at all my man in fact you just pushed forward my research as I just measured the thickness of the rear hub flange and it is 11mms. I checked the number of turns you need to fit a standard steel wheel and it was about seven and a half. I then checked the number of turns fitting an alloy wheel and it was about five and a half.
So if you do the maths the 1.25 pitch in an 11mms flange gives you 7.3 threads or turns. So it looks like you only need to have the bolts 3mms longer . I have only worked with older Wolfrace , Uno Turbo and Cromodora alloys, it could be that more modern wheels can use shorter bolts so it is easy to check just by taking out one bolt to see how many turns it takes to tighten. I spoke to a guy recently who sells BMW bolts that are the same spec as the 126 and he recomended 7 to 8 turns minimum. Having said that I am driving around with the standard bolts at the moment and I know that some guys have been running them for years  :)
« Reply #5 on: October 18, 2011, 09:04:43 PM »
Will this do?
McGard brand
Type: Lockable wheel bolt
Thread size: M12x1,5
Seat: 60°/cone
Shaft length/total length: 29,5 mm
Shaft diameter:
Hex size: 17 mm
Presume the hex size is the size or diameter of the bolt head. I shall check the shaft length.
