Hi! I'm in this movie
but with modified engine, I hope it will be done soon.
In brief - yes, it fits, and no - not directly. So, you can put it easily with the proper manifold, but you need to rejet it for the needs of your engine.
Usually you can not find Dellortos from 1300cc engined Alfas, then you have to make the software inside like for it. Using the original jet combination for Alfa Romeo 1300 GT Junior (I'm still looking for the factory jetting from reliable source) is a good starting point that might be OK with more luck. Then you need the supposed jet sizes and close sizes up and down. The adjustment is kind of art and you need some tools, knowledge and nerves or a guy that knows his job.
It's costly, cos you need couples of all jet sizes, at least there is
http://www.dellorto.co.uk/, they got everything and in many cases original.
For sure you need 28mm Venturi chokes (8383.28) for 325cc per cylinder. And maybe Auxiliary venturi 7848.1 if it doesn't work nice with 7848.3 (that you will probably find in whatever you buy). Then the jets as we said.
If you put such a stuff, better forget about the original silencer.
The carb adjustment is the last thing you have to do after the silencer, air filter, trumpets (maybe), spark plugs..., cos once you change something of those, the jetting becomes unproper in one or other way.
Wish you luck!
