Author Topic: the rear panel bit  (Read 1251 times)
mic
the rear panel bit
« on: September 09, 2011, 08:08:43 PM »
hi!
as you look at a 126 from behind, the panel with the boot/engine door.... if you take the door part off is it just one large panel that unbolts to remove the back end??
cheers
Re: the rear panel bit
« Reply #1 on: September 12, 2011, 07:36:33 PM »
in a word yes.
RicePuddin
  • Guest
« Reply #2 on: September 12, 2011, 10:07:11 PM »
someone advised before that it's easiest to leave the bumper on too when removing the panel.
« Reply #3 on: September 13, 2011, 12:11:18 PM »
if you removing the engine then leave the rear panel and bumper on for a rapid refit.
