Author Topic: HID xenon lights  (Read 2213 times)
RicePuddin
  • Guest
HID xenon lights
« on: September 05, 2011, 09:55:56 PM »
Does anyone know what the ballast thing does on these kits? I've Googled it but can't find anything.
I'm going to fit some halogens for extra light. I don't want to put any spots on the front as I haven't found any that I like.
eben80
    • AircooledVWSA
Re: HID xenon lights
« Reply #1 on: September 06, 2011, 10:00:43 AM »
On actual HID Xenon lamps it provides high voltage and a starting circuit to maintain the arc between the two electrodes in the lamp. HID Xenon lamps do not have filaments so require circuitry to make adjustments to the current & voltage to keep the arc constant.
Halogen "xenons" however do have a filiment but are a load of rubbish, playing on the word xenon....
Just note though, if you fit an aftermarket HID conversion kit to non-projector style standard reflectors, you WILL annoy and blind other motorists on low beams and you SHOULD fail your MOT.  ;)
RicePuddin
  • Guest
« Reply #2 on: September 06, 2011, 02:40:37 PM »
I had trouble trying to find a place that sold halogens that fitted. Everyone told me that they were the old type and would be hard to find. I found a supplier and bought 6.
DEYAN IYI
« Reply #3 on: September 07, 2011, 11:44:29 AM »
Certainly you have the non H4 type. The halogen bulbs are hotter and will "burn" the mirror cover soon. Also the simple lamps are 45/50W and the halogens 55/60W. It means that if you run them without relays, they will melt the switches or even wires (ordinary bulbs need relays as well). You better find H4 reflectors and put some nice bulbs like for example Osram Night Breaker Plus. Then you need a proper wiring - lovely fat wires and good connections. Here goes a good article.
The good thing about HID Bi-xenon system is the consumption of 2x35W. Something important for 126. There is solution for the projectors. You can instal them in the standard H4 reflector, removing the glass that anyway needs to be replaced by a smooth surface one. You can shape it after the original one in special camera in vacuum - look here. I don't know what MOT-ers think about it :)
Hope it was helpful :)
RicePuddin
  • Guest
« Reply #4 on: September 07, 2011, 04:54:14 PM »
Can someone confirm if a 1991 Bis has a relay fitted.
RicePuddin
  • Guest
« Reply #5 on: September 07, 2011, 08:00:02 PM »
I found it  :)
pav
« Reply #6 on: September 27, 2011, 11:22:51 AM »
It is bad idea.
1st The car headlamps was originally designed to R2 bulbs and when fitted with H4 (later models) sill were blinding other road users. With hids u will be flashed constantly by other drivers.
2nd It will be probably an MOT fail
« Reply #7 on: September 27, 2011, 09:53:03 PM »
I confirm that the 126 Bis has a built in relay. I use H4 halogen bulbs. The brightness is sufficient i.e much better than the R2s. There have been a lot of threads on the Xenon debate but Deyan Iyi's suggested solution has never been debated. Very, very interesting.
Deyan Iyi have you fitted one to your 126 or know someone who did?
