Author Topic: Re: Windscreen water reservoir with electric pump for 126 Bis  (Read 1953 times)
« on: September 05, 2011, 01:45:20 PM »
Just to confirm - I still need the above for my blue 126 Bis. I have a dumb question. In the absence of a secondhand re above, can I use the screen washer bag and electric pump of other cars? Subject to the shape of bag or plastic container, the pump should work as it also uses 12v. There will probably be issues with fuse amperage. What do guys think?
Emin
« Reply #1 on: September 05, 2011, 03:31:04 PM »
Shouldn't cause much trouble. If it's the pump motor, you may fit another one to the existing water container with some fiddling i guess.
« Reply #3 on: September 08, 2011, 08:27:57 AM »
Think there was one in that bunch of stuff I took to Retro Rides
« Reply #4 on: September 10, 2011, 11:41:07 PM »
Kindly check and let me know please if you have one.
Bar Vitelli
« Reply #5 on: September 11, 2011, 08:10:48 AM »
There's a chap on eBay breaking (heartbreaking) a 126 Bis for spares so he will probably have the part you need at an affordable price.  I don't know how to insert the link but if you search 'fiat 126 bis' using 'all categories' you should find him, he's based in Blackpool.
Every cloud has one...
RicePuddin
  • Guest
« Reply #6 on: September 11, 2011, 09:58:45 AM »
A few cars in the fiat range used bags for their washer fluid. If they are all a standard size a scrap yard might be a good place to look.
