Hi Guys,
Am having a little trouble getting to the cause of the poor hot starting and uneven idle with aircooled.
Have done the usual tappets/condenser/points.I did however find a crack in the bakelite spacer of which i have replaced and whilst carb was off stripped,cleaned etc including checking float etc.
Idling a little better but now does spit back from the carb on the over run.Would it make a difference as i had not fitted the plastic elbow to aircleaner?
Starts on the button from cold and runs great until its hot and you try and re-start it after 5/10 mins !!
Can anyone give me any pointers please?
I haven't re checked timing since engine was built 150 miles ago.
Many thanks in advance.
Mazz
