Fiat 126 Chat
Fiat 126 Chat
Spare key for my 126 Bis
Pages: [
Topic: Spare key for my 126 Bis (Read 2244 times)
Subscribers
on:
July 19, 2011, 10:58:40 PM »
Does anyone know how to get a blank key for a 126 Bis. My blue 126 Bis came with just one key. There was a thread on this previously. It mentioned ordering a spare key from a Fiat dealer based on numbers stamped on the key but mine does not have numbers or codes stamped on it. My cream Bis does not have numbers either. My local Timpson was unable to help but suggested I try a master locksmith but I thought that was what they were. Can I purchase a blank key from Poland? Any ideas?
Administrator
Re: Spare key for my 126 Bis
Reply #1 on:
July 20, 2011, 12:20:08 AM »
Looks like you will have to get a new one cut. There are fiat blank keys available on ebay, just make sure you pick the right one.
Eklipze3k
Reply #2 on:
July 20, 2011, 09:12:24 AM »
I could be wrong but the BIS doesn't have an immobiliser does it? In which case, the key won't have a transponder in it and there will be no receiver for it in the ignition barrel. In this case, Timpsons et al will have no problem literally just copying the key, of course if you want one with a proper FIAT end on it then you'll need to have a look for the appropriate blank.
I saw a thread recently on FiatForum where a guy had taken the blade of his key and put a screwdriver handle on it, it looked cool
Subscribers
Reply #3 on:
July 21, 2011, 06:06:41 AM »
The key does not have a transponder. I'll try another Timpson. I checked Ebay, visually, the closest key to the Bis appear to be either the Uno/Cinquecento or the X/19. I'll try my local Fiat dealer as well to see what they can do.
Subscribers
Reply #4 on:
July 21, 2011, 06:12:57 AM »
Ebay sells new Fiat 500 transponders. I'll investigate to see wether I can attach the key (when I find one) to one of those. Presumably, they are just the casing. The srewdriver handle idea sounds good too. Did he cut 99% of the screwdriver and then weld the key on?
Eklipze3k
Reply #5 on:
July 21, 2011, 03:42:40 PM »
See for yourself
http://www.fiatforum.com/cinquecento-seicento/277262-me-n-mrs-got-bored.html
Pages: [
Fiat 126 Chat
Fiat 126 Chat
