Author Topic: How easy is it to fit a 126P engine into a UK car?  (Read 1850 times)
kartman
« on: July 11, 2011, 06:47:36 PM »
Is the 126P ELX 650cc air cooled engine fairly easy to fit and get running into a UK car, the big difference seems to be the ignition system (no distributer) Has anyone on here done this? Also does the gearbox from  Polish aircooled 126 fit straight onto the back of a UK 126 engine and work ok? Many thanks..........Martin
Re: How easy is it to fit a 126P engine into a UK car?
« Reply #1 on: July 11, 2011, 07:26:54 PM »
I think the ELX has a cat. converter and a charcoal filter to bring down emissions (and the Weber 28 IMB 10/250 carb with the idle solenoid valve) but everything else is the same. UK car as in RHD? The engine and gearbox positioning isn't effected by the position of the steering wheel...
kartman
« Reply #2 on: July 11, 2011, 07:39:31 PM »
Left hand drive, car bought as a scrapper. I have a nice 500 with a suspect 650 engine and it`s original crash box and was wondering how dificult it would be to switch it over, i know the drive shafts would need changing for the 500 ones. How would i go about sorting the ignition issue out......any ideas?........Martin
« Reply #3 on: July 11, 2011, 10:41:03 PM »
Sorry did you say the poor little ELX has been murdered for a 500 :o
 :D ;D
I am sure a 500 person can help out. ELX wasn't sold in the Uk, Different ignition as already said. Wiring won't be straightforward, but if you have the whole 'dead body' of the 126 you should be able to remove the whole loom.
124cso
« Reply #4 on: July 13, 2011, 12:26:34 PM »
Just swap the whole power unit over. A 500 gearbox will not bolt up to a 126 motor. You need to have a 126 bellhousing and graft your 500 box to that. Easiest just to swing in the whole unit, axles and all.
« Reply #5 on: July 13, 2011, 01:23:38 PM »
If you fit the 126 gearbox/axle in a 500 you have to do one of two things replace the 126 shafts with 500 shafts or fit 18mm distance pieces between the swing arm and the rear bearing hiousing, you will need longer bolts. Installing the distance pieces may require body mods to the wheel arches for clearance.
