Author Topic: Stuttering under prolonged load  (Read 2174 times)
Funkin Go-nut
« on: July 08, 2011, 08:55:59 AM »
Running on the flat at 50-60mph my a/c is absolutly fine, but when climbing hills it starts off ok, but when you give it more gas to maintain speed, after a while the engine starts to stutter a bit and lose power. When you reach the top and hit the flat again its fine.
Any ideas as to whats happening/whats causing the problem?
FGN
midvillesb
Re: Stuttering under prolonged load
« Reply #1 on: July 08, 2011, 08:20:20 PM »
Sounds like fuel starvation - I had a similar issue only much worse (stuttering/jumping on any incline and even on the flat above 30mph). Turned out to be a sticking float valve in the carb in my case but I would also check that the fuel filters aren't blocked or could be a worn fuel pump (or the push rod that powers it).
Might also be worth checking the points gap - if they're wrongly set the effect under engine load can be similar to fuel starvation.
Mike
« Reply #2 on: July 08, 2011, 09:24:01 PM »
I can rember on the 500 site someone had a similar probem turned out to be sticky weights in the distributor, wouldn't advance/retard properly, a clean and oil up solved his problem.
Funkin Go-nut
« Reply #3 on: July 09, 2011, 03:38:07 PM »
Thanks for the coments, i will check.
It shouldn't be fuel starvation on the pump side as I have an elecy pump fitted, but you never know  ::)
