Hello everyone, I'm in deep trouble, and would appreciate any knowledge!
Here's a step by step rundown of 'what happened today': (Mr car is a 1989 aircooled 126)
1. I was driving at about 30km/hr in second gear when I heard a 'bump' come from the bottom rear of the car. A half second later my driving wheels locked, and both wheels skidded for a few metres.
2. The engine was still running because I had pressed the clutch to avoid stalling. But the engine was labouring as if the clutch was still half engaged. I just couldn't get it out of second gear to begin with. I switched off the engine.
3. Checked underneath the car, no branches or obstacles stuck under there and nothing stuck in engine. Swore a lot.
4. Managed to disengage second gear into neutral and pushed the car into my shed. The car made a weird clunking noise at regular intervals as I pushed it along.
5. I started the engine again, and whilst in neutral I noticed the engine is a bit out of balance. It also makes a bit of a weird noise like something is shaking around and whirring. But when I pushed the clutch in this would stop and it would run properly.
6. I put it into reverse and let the clutch out, the car reversed for a metre or so and then the wheels locked and the car bumped to a stop.
PLEASE does anyone know what is happening here? It's either the clutch, differential or gear box but I have no idea which. The gears still seem to be engaging. To my knowledge there have been no oil leaks from the transmission but to be honest I have never filled it up in the two years I've had the car.
The transmission had been making a deal of noise recently, but I thought it was the rubber mounts that had just worn..
Please if you guys have experienced this situation or you think you could help out then please give me a few ideas! Thanks also for all the help in the past.
Alley.
