Author Topic: Front and rear shock absorbers  (Read 1955 times)
« on: June 28, 2011, 10:38:59 PM »
I am not sure whether this topic has come up before. How does one know whether the shock absorbers of a 126 need replacing. It is relatively easy to gauge on conventional cars whether the shocks need replacing but not the 126s. The front leaf spring configuration makes this difficult. Unfortunately, one end of the leaf spring on my blue Bis has straightened due to the shock absorber not working for quite a while. Despite this, the car drove normally. I now need to source a new or secondhand leaf spring which could have been avoided if the shocks were replaced. Are there any telltale signs? I am a bit worried about my cream one although it has only done 17K whilst my blue one, has done 43K miles.
What about the shock absorber rubber bushings/mounts (top and bottom?).
« Last Edit: June 28, 2011, 10:54:35 PM by Amateb8 »
silvaspeeder
Re: Front and rear shock absorbers
« Reply #1 on: June 28, 2011, 10:48:32 PM »
I would also like to know this.  I bought a 1992 Bis on saturday and the leaf spring seams rather flat. The tyre on the O/S is almost touching the wheel arch (even without me in it!) but the N/S isn't.
Would this be the leaf spring or the shocks?
« Reply #2 on: June 28, 2011, 11:16:17 PM »
If you have watched your car being MOT'd the examiner bounces the car on each corner to test the resistance of the shock absorber, If the spring has sagged on the o/s its more likely to be because most cars are only driven by the driver with no passengers, I have in the past taken the spring off and turned it the other way round to level the front of the car up :)
silvaspeeder
« Reply #3 on: June 29, 2011, 09:00:51 PM »
Thanks I'll look into it. ;D
« Reply #4 on: June 30, 2011, 07:36:50 PM »
True that it's hard to tell what the shocks are like at the front because the leaf spring makes the front firm, however if it looks as if one of the wheels is nearly touching the arch then it's probably a broken spring leaf. If there's oil seeping out of the shock or there's that oily dusty stuff on it then it's probably on it's way out. I had two broken leafs and couldn't tell but now that's it's been repaired it really has made a difference (and the front became a bit higher). The rear shocks are easier to tell, if the rear becomes bouncy then it may be worn shocks. Best is to take the car and have the shocks tested like they do at the MOT. If you want to check ball joints and bushings at home have a helper shake the wheel while you're looking under the car at the bushings. If the bush moves around (like if it has a life of its own) then it's worn. You can also check the kingpin and wheel bearing play and the shock absorber bushings too. You can check the ball joints by having the helper move the steering wheel quickly from left to right while looking at the ball joints (if it's really worn then it may even make a knocking noise but  remember that these steering mechanisms have larger play).
« Last Edit: June 30, 2011, 07:42:31 PM by GTMaster »
