Author Topic: Exhausted  (Read 1863 times)
Funkin Go-nut
Exhausted
« on: June 28, 2011, 03:54:09 PM »
What are the benefits/problems associated with the exhausts that replace the L shaped manifolds?
Re: Exhausted
« Reply #1 on: June 28, 2011, 05:31:37 PM »
The benefit as I understand it is that the gas flows better as the elbows were quite a harsh turn for the gasses.
I see a benefit of not having the extra exhaust joints as wherever there is a joint, there is the potential for a bolt or two coming loose.
Also the exhaust ports from the exhaust should be able to be made bigger but I would check on that.
The only downside I can see is that bolts would have to be used to fix the exhaust to the head instead of studs.
I believe studs to be better as once locktite-d in the threads do not wear no matter how many times one takes them off.
I don't kow if this is correct, any comments?
Re: Exhausted
« Reply #2 on: June 28, 2011, 06:48:37 PM »
I was having a chat with one guy from this forum who has had many years of tuning the aircooled engines and also makes his own stainless exhausts. He always does away with the elbows. Also I would just fit shorter studs.
