Author Topic: Will they fit with spacers?  (Read 6517 times)
Draigflag
  • Got a New Abarth 500 too!
« on: June 27, 2011, 06:16:43 PM »
Bit of an obsession going with wheels here! Just got some Fiat 131 Mirafiori wheels from eBay. Just tried them on the 126 (without tyres) and they seem very close to the body.
Question is, will they fit with some spacers, how do I find out and if so, where can i get some spacers + extended bolts?
Sorry to be a newb!  :$
Draigflag
Re: Will they fit with spacers?
« Reply #1 on: June 28, 2011, 08:07:54 AM »
I guess no bdy knows then. I'm going to order some spacers and longer bolts and hope they fit. Will they be safe though? Or will there be balancing issues due to the cars size?
DEYAN IYI
« Reply #2 on: June 28, 2011, 08:24:26 AM »
I don't get the problem. What is "they seem very close to the body"?
If I can picture it well, with spacers will be even worse.
Eklipze3k
« Reply #3 on: June 28, 2011, 10:16:59 AM »
It's all about offsets. From what I understand the 126's offset is ET35 so what's the offset of your 131 wheels? If it's higher than ET35 you can use spacers to reduce the gap, if it's lower than ET35 then there is no (cheap) way to correct it.
124cso
« Reply #4 on: June 28, 2011, 01:53:22 PM »
I'd suggest you check with wherever you go for your MOTs. They can be a bit funny about such things, Be a shame to buy wheels, tires, spacers & new bolts to have them condemmed at next MOT.
Especially if you have dumped your old wheels & tires !!!! Spacers are banned here.
Draigflag
« Reply #5 on: June 29, 2011, 06:16:42 PM »
I'm not sure of the offset, should it be stamped on the wheel? Basically i want 10 or 20 MM spacers (like giant washers) between the wheel and the hub so it's (in theory) further away from the car body. The 131 wheels are 1 CM narrower than the Cinq alloys which fit fine, but the stud holes are closer to the face of the rim so the back of the rim is closer to the car.
Really sorry about the poor explanation. I've got my mate to stick a tyre (from the Cinq Alloys) one the spare rim so i can fit it and see if there are any real clearance issues. If i can't figure this one out then i guess i'll have to flog them again  :(
Eklipze3k
« Reply #6 on: June 29, 2011, 11:04:45 PM »
The offset should be stamped on them, something like ETxx (where xx is a number). I'm not familiar with the wheels, are they 13x5j?
Anything over 8mm spacers and I'd be looking hubcentric, richie.guy on FF sells sets for a decent price :) But don't look at spacers until we know what size you need, I can't imagine you'll need any bigger than 10mm tbh, 20mm will probably cause problems the other way, lol
Draigflag
« Reply #7 on: June 30, 2011, 07:47:58 AM »
Thanks for your help. Can't see anything on the wheels besides 5j x 13 and 1082? I'll have a closer look tonight. Pic below of what they look like, thought they'd look pretty smart on the 126!  :D
Draigflag
« Reply #8 on: July 02, 2011, 06:20:34 PM »
Still trying to get my head around this issue. How about these? Will they fit the 126? They seem to have the right sizes etc.
http://www.ebay.co.uk/itm/FIAT-CINQUECENTO-HUBCENTRIC-WHEEL-SPACER-KIT-15MM-/300505716934?pt=UK_Cars_Parts_Vehicles_Wheels_tyres_Trim_Nuts_ET&hash=item45f78958c6
124cso
« Reply #9 on: July 02, 2011, 11:40:40 PM »
They are a stock Fiat wheel but trying to recall from which model/s. Try looking for pics of 128 sport, mid to late 70s ?
124cso
« Reply #10 on: July 02, 2011, 11:42:51 PM »
Look a bit dodgy to me. Sure they are 4/98PCD ??
Eklipze3k
« Reply #11 on: July 03, 2011, 09:09:33 AM »
He said at the start they're from a 131 Mirafiori. I'd be dubious about those spacers personally, but you can always ask the seller just to clarify as the listing says VW fit, then goes on to say 4/5x98 so it can't be both or even all 3! But we need to make sure 15mm is the right size, too.
Draigflag
« Reply #12 on: July 03, 2011, 10:01:04 PM »
Oh damn, why are simple things so hard to work out? I love these wheels, i want them to fit!  :(
Eklipze3k
« Reply #13 on: July 03, 2011, 10:50:17 PM »
I've just been doing a bit reading, apparently some of the alloys were ET0 and fitted with 30mm spacers, which would make the car (131 that is) ET-(negative)30. Based on that if these wheels fit straight onto a 131 with no spacers then there's not a hope they'll go onto the 126, but looking at the picture I doubt that's the case. Rather than you splashing out, I've a set of 10mm hubcentric spacers. If you can get the car here you're welcome to test fit them and see how it looks/feels, probably better than spending money on a set too find out they're too big/small.
124cso
« Reply #14 on: July 04, 2011, 02:41:34 PM »
Thanks for your help. Can't see anything on the wheels besides 5j x 13 and 1082? , thought they'd look pretty smart on the 126!  :D
I would have thought a 131 would have had 5&1/2" J rims ?, that's why I sugested 128
