Author Topic: 3rd gear hard to engage  (Read 3350 times)
fiatmaluch126
« on: June 25, 2011, 06:26:33 PM »
Hi all, yet another problem, well 2 actually! (Don't you just love these cars!?)  :P
1st problem, when driving i'm finding it hard to get into 3rd, any ideas? (clutch pedal is slightly lower than brake pedal height by the way!) also, someone said its something to do with linkages on gear stick/selector. Common fault??
2nd problem,  how do you get the square nut off the gearbox to check/top up oil level? (tried 13mm open ended spanner no good, won't budge!)   >:(
Keep the Faith all! Regards David
KAL SPL
Re: 3rd gear hard to engage
« Reply #1 on: June 26, 2011, 01:43:39 AM »
If you do get it into 3rd does it pop out by itself or come out very easily ?
1 of the main bearings will be worn out , had the same issue years ago and my second gearbox is just strating to do it aswell I think.
Aus's cleanest Niki !
fiatmaluch126
« Reply #2 on: June 26, 2011, 06:57:34 AM »
Hi Kal, it's just hard to put in third, stays there when in and changes to 4th ok.
Allan
« Reply #3 on: June 26, 2011, 09:46:55 AM »
Have a look at the flexible coupler on the gearshft shaft.
fiatmaluch126
« Reply #4 on: June 26, 2011, 09:50:04 AM »
Hi Allan, is that the flexible joint that connects the driveshaft to the rear hub?
Allan
« Reply #5 on: June 26, 2011, 09:56:30 AM »
On the second problem of the gearbox checking plug. If you have a well worn half inch drive extension you may be able to get it onto the square. Or try to find a 13mm square socket. Square sockets used to be quite common some time back but don't seem so popular now. You could undo it with a cold chisel but this is not recommended as you could break the gearbox housing. If you have an old worn socket (12 point) that wont quite go on the plug try tapping it on.
Allan
« Reply #6 on: June 26, 2011, 09:57:33 AM »
No it's in the gearshift shaft just in front of the box.
fiatmaluch126
« Reply #7 on: June 26, 2011, 10:08:20 AM »
Ok Allan, thanks for that i'll keep you informed of how i get on!  :thumbup
124cso
« Reply #8 on: June 28, 2011, 01:44:14 PM »
The question of the gearbox filler plug was discussed at length on here only a few weeks ago.
Get yourself a 12mm allen key or a 12mm hex bit for your socket set, like you would use to undo sump bung on most 1960s 70s or 80s fiats. Now make sure square head of bung is clean and not burred, take your 12mm socket and tap the square end onto the square gearbox plug. Tap, don't pound it. Now stick your allen key or hex bit in the exposed hex of said 12mm socket and apply effort.
These are often quite tight. I think they get tight because people (correctly) drain gearbox oil when it is hot and by the time they have put the big 1.1 litres of new oil in and refit the bung, the housing is still warm (the mass of the diff head is just behind that bung) and then cools and shrinks onto the bung ?
Other prob of selecting 3rd, is it only 3rd or 1st also ? If it is 1st also, start by adjusting the front selector /gearlever bolts. Gees there are times when you just gotta look at the book!
« Reply #9 on: June 28, 2011, 05:20:23 PM »
Last weekend i pulled apart my gear selector (gear stick etc) 'cause i couldn't engage reverse, though all forward gears were selectable. The self locking nut on the bottom of the gear stick had gone loose (i left it  loose when i put it together so that shifting would be smoother though it's better if it's nearly totally tight) and was wobbling everywhere. Best to first check that everything is tight and aligned before pulling apart or taking the gearbox off.
fiatmaluch126
« Reply #10 on: June 28, 2011, 10:15:06 PM »
Ok, problems almost sorted thank you all! and thanks 124cso, i did look in forum search, and my 1973-1977 book but not much help! anyway my mechanic m8 did it for me this morning as you've described and fresh oil inserted, as for 3rd gear i adjusted the clutch cable and it doesn't do it as often now. Regards to all members for their help! David   ;)
« Reply #11 on: June 29, 2011, 08:17:11 PM »
I've found as I did this evening, when you push fairly hard it will momentarily not want to go into third.
It's always done this, I have always thought it is because perhaps the engine has tilted slightly  because of the high revs or something.
I thought maybe a good modification would be some sort of sideways mounting because the only thing stopping the engine swaying about in the back is the gearbox mounts.
fiatmaluch126
« Reply #12 on: June 30, 2011, 09:12:28 PM »
Hi Darrell, since adjusting the clutch cable and tightening right side gearbox bracket bolt it's a lot better, not 100% but 90%. But my front brakes still pull to the right until cars warmed up!  :(
nrg19uk
« Reply #13 on: June 30, 2011, 11:16:02 PM »
Sump plug key is good for undoing the gearbox plug have a look on eBay only 15 pounds for a set.
Neil gargaro
