Author Topic: changing the instrument lights to leds  (Read 2099 times)
nrg19uk
« on: June 25, 2011, 03:35:58 PM »
i thought id put a post up of how to change the standard lamp for a led strip on the instrument gauges for a much brighter, more even, and power saving mod.
first remove the speedo cable and the two plugs from the rear of the gauge, undo the two holding screws and remove the unit.
remove the two screws circled in red holding the front plastic in place
Then remove the three small nuts and washer and the two screws circled in red, the one marked in yellow is where the connection will be made at a later date.
carefully separate the clocks from the casing i found holding the part that connects to the speedo the safest way whilst undoing the screws.
this is the self adhesive flexible led i used it comes with a little cable clamp connections and can also be cut too size.
now remove the lamp holder marked in yellow and make a small hole in the side of the green plastic lens, feed the cable through the hole and peel of the sticky back and stick into place.
now remove the lamp from the holder and remove the metal prong parts, there a bit fiddley to get out i used a screw driver and prised them out, then solder them to the ends of the cable
now push the metal parts back in the lamp holder
this is the important part push the lamp holder back in its hole but the red cable must go where the arrow is pointing to or the leds wont work they must have the right polarity.
test in the car!! :P
reassemble the clocks in the reverse of disassembly (do not over tighten the small nuts holding the fuel gauge on)
sit back and enjoy  8) 8)
Neil gargaro
fiatmaluch126
Re: changing the instrument lights to leds
« Reply #1 on: June 25, 2011, 08:52:58 PM »
Very nice!  ;) but doubt it will be as easy in my 1999, 126 different clock set up.
« Reply #2 on: June 25, 2011, 09:05:21 PM »
For newer ones you can just change the bulbs. LED bulbs direct replacements on Ebay.
fiatmaluch126
« Reply #3 on: June 25, 2011, 09:15:48 PM »
Oh right! Nice one! i'll check them out  ;)
nrg19uk
« Reply #4 on: June 25, 2011, 09:16:40 PM »
Can you post up a picture I've never seen a newer dash. Like dajwid said you can get replacement lamps Im not sure you would get the same effect/brightness as I was after, but it would be alot easier.
Neil gargaro
« Reply #5 on: June 25, 2011, 09:26:40 PM »
I mean the Bis type dash.
(Note not my car in Picture)
fiatmaluch126
« Reply #6 on: June 25, 2011, 09:31:06 PM »
Mines similar but not all the lights on left
