Author Topic: Tyres  (Read 2406 times)
Funkin Go-nut
Tyres
« on: June 24, 2011, 02:53:15 PM »
Ok I need some new tyres for my 126, and I was wondering if going retro and getting 125/12 Pirreli's was a better option that 135/12 Debica's or other makes I've never heard of...?
Is it a quality verses width and cheapness question or should I try and put as much rubber on the road as possible regardless of make?
fiatmaluch126
Re: Tyres
« Reply #1 on: June 24, 2011, 03:09:33 PM »
Hi Funkin in my case any tyre is good as long as its safe, i've just bought a good one off an old man, on the wheel for 20 pln which is £4.50 gbp. I run on debica's and no problems noted!
Funkin Go-nut
Re: Tyres
« Reply #2 on: June 24, 2011, 03:19:08 PM »
Sounds like a bargain  8)
Three of the tyres have multiple cracks in the sidewalls and tread area, and one of them has perished/started to rot by the look of it so I need to do something.
I'm open to ideas/suggestions... :)
I've also phoned a couple of local tyre places and they have all been useless regarding getting hold of 135's so I will probably have to mail order..
« Last Edit: June 24, 2011, 03:22:19 PM by Funkin Go-nut »
Re: Tyres
« Reply #3 on: June 24, 2011, 04:06:33 PM »
125s were never fitted to the 126, they were strictly Fiat 500. they are now only produced in small batches I believe hence the price. Ricambio are selling them for just under £70 a corner then you need the right size inner tubes at £12 to 20 each. If you are passing by I have some good used 135s in my shed  :D
Funkin Go-nut
Re: Tyres
« Reply #4 on: June 24, 2011, 04:37:48 PM »
Hmm it starts looking expensive, didnt know that the 125's needed an inner tube..
Are 135 13's the same rolling circumference as the 135 12's as there seem to be a lot more makes of tyre's available for that size?
Also which 13 inch wheel fits/has the correct offset? ie Punto, panda, cinq, siecento steel wheels etc?
Funkin Go-nut
Re: Tyres
« Reply #5 on: June 24, 2011, 04:55:24 PM »
I do have a set of 14" alfa wheels but i believe that there isn't a tyre skinny enough to fit without rubbing problems?
Re: Tyres
« Reply #6 on: June 24, 2011, 05:17:57 PM »
X-19 wheels look good and plenty about at a good price
Kipster
Re: Tyres
« Reply #7 on: June 25, 2011, 05:24:31 AM »
I know where there is a set of x-19 alloys. Will the 155 tyres fit the 126?
I'm just thinking of the future, it seems 12 inch tyres are a silly price, maybe spend the money on refurbishing the alloys instead.
Funkin Go-nut
Re: Tyres
« Reply #8 on: June 28, 2011, 02:27:30 PM »
ive found someone who will swap my alfa 14" for 13" so I will probably get 145/70/13 tyres as they seem quite reasonable...
