I had fuel starvation, read through old posts here and decided it was the pump. So I fitted an electric one, problem cured.
30 miles later fuel starvation again just as bad as before...
Turns out the pipe from the tank was blocked, I think it was blocked enough to stop the mechanical pump sucking, the electric one had more suck and worked until the pipe was pretty much blocked solid - I can't blow down the pipe at all so got to get the tank out and give it a clean inside.
How does it come out please, I had a quick look in the dark last night but couldn't see any nuts or bolts?
