Author Topic: Column light switch question  (Read 1840 times)
hudsonhenry
    • http://www.retro500.com
« on: June 18, 2011, 12:03:48 AM »
I'm in the process of building a custom wiring loom for my 500 and have a question. I assume that the 500 is the same as an early 126 with a lights on switch on the dash and then a three position arm on the steering column. My question is this: which order are the lights? side top of the arm, main middle, dipped bottom or is the order different?.
Nigel
Re: Column light switch question
« Reply #1 on: June 18, 2011, 12:22:21 AM »
Nigel hope this helps
« Reply #2 on: June 18, 2011, 10:06:04 PM »
I have an interesting column switch: the lever cannot be pushed upward only downward (high beam works though)...
Allan
« Reply #3 on: June 19, 2011, 02:32:18 AM »
Sorry to use this forum but is that the same hudsonhenry that appears on Guy Crofts site?
hudsonhenry
« Reply #4 on: June 19, 2011, 05:39:38 PM »
Yep, tis one in the same :$
Thanks for the replies, I though it might be that way around, I can't get my column levers to work right. I have off at the top with a pull back flash, main beam in the middle and dipped at the bottom again with a pull back flash. I am using the original column switches to run to relays and then onto a custom loom that incorporates the wiring for the cooling fan, electric water pump, digital controller etc. I must have something around the wrong way but I cant work out what!
