Author Topic: blue print or enlarge  (Read 1796 times)
Oldsmoker
« on: June 16, 2011, 10:25:20 PM »
does enlarging the cc to 800 add significantly more than just building a fast road spec engine?
DEYAN IYI
Re: blue print or enlarge
« Reply #1 on: June 18, 2011, 12:20:37 AM »
Well, for 126 everything is "significantly more" ;D But depends on aim.
For sure there will be better torque. For example:
126 600cc 38,7Nm/3400rpm, 263* camshaft
126 650cc 42,0Nm/3000rpm, 263* camshaft
126 Bis 700cc 49,0Nm/2000rpm, 256*camshaft
Cinquecento 700cc 52,0Nm/3000rpm, 253*camshaft
So, +50cc gave +8,5% of torque. (The only difference inside the engine is the volume.)
And, +50cc gave about +20% more. (But double ported heads and real carbs.)
In total +100cc gains about +25% more torque.
Then theoretically if we have a double jump 600 to 700 = +25% (40 to 50Nm) and 700 to 800 = +25%, according to our parrot method, the result should be about 62,5Nm out of 800cc Maluch or lets say 60 to 65Nm ;D Not bad...
If we play the same with the horse power, we should expect about 35hp.
But it's like "making a bill without the bartender" ;) Everything depends on everything...
« Last Edit: June 18, 2011, 12:26:58 AM by DEYAN IYI »
124cso
« Reply #2 on: June 22, 2011, 01:03:28 PM »
But isn't the main problem going to be the gearbox and what it can stand ? You can probably fit 1200 - 1500cc of motorbike V-twin in there comfortably but you won't get the power to the ground (for very long anyway)
DEYAN IYI
« Reply #3 on: June 25, 2011, 10:10:32 PM »
Well, the gearbox is always a problem. A friend of mine destroyed 2 boxes in a couple of days with FIRE 55hp Uno's motor. Without pushing a lot. He even haven't make the final adjustments. So he left it... Waste of time and money and ... enthusiasm.
Maybe the "best" choice for a 4 cylinder engine is FIAT Panda 34 (late 750): 34hp/5250rpm and 57Nm/3000rpm. It looks similar to Abarth 695SS which has 38hp/5350rpm and his gearbox is nothing special, I mean harder.
With more powerful engine will need 9/39 pinion and crown (from Bis box). This Panda actually has 5 speed gearbox, but 126 is 100kg lighter.
It will run nice... 80 miles like nothing... but no fun ::) You see a 126, hear "one of the crowd"... You open the engine room... Something makes you wanna puke :$ Something boils water...
About the 800cc aircooled, the parrot method for predicting a power works  :o Look the graphics. So, if someone wants to ride a fast 126, he can build in a ready made stuff. But the other way is longer, winding, but there is art in it ;D
Anyway 800cc will be real heater for the wicked head ???
