Author Topic: headlamps and hose  (Read 2100 times)
badboy
headlamps and hose
« on: June 10, 2011, 07:11:52 PM »
headlights plus the pipe that goes from carb to air filter as mine has perished and split
where can i buy one of these?
also headgasket has gone and i was close to giving up as well but if it can be done and i can find last of parts i will carry on with the resto
i know a forum member has some new ones  :o
hadn't realised they were that much he also has second hand ones but i am trying to get in touch with the people that live near wakefield as they are nearer
any one have their contact details?
« Last Edit: June 15, 2011, 07:27:54 AM by badboy »
Kipster
Re: headlamps and hose
« Reply #1 on: June 12, 2011, 02:07:18 PM »
Check out for lamps for a fiat 127, im sure they are the same.
fiatmaluch126
« Reply #2 on: June 13, 2011, 07:56:53 PM »
Hi Badboy, last resort try  www.allegro.pl   theres loads of parts for bis also ive checked today. Regards David
« Reply #3 on: June 13, 2011, 08:38:10 PM »
They will be left hand drive headlights on Allegro. It is possible to change lenses, but fiddly.
« Reply #4 on: June 13, 2011, 10:57:53 PM »
I just bought a pair of LHD headlights from 126fan about a month ago, they were 12 euros each, not sure about the postage as i bought some parts 126 stuff as well, as far as i'm aware you can use these headlights in the U.K. as long as you stick a beam deflector on (the black vinyl type) when it goes for its MOT :thumbup
http://www.126fan.sk/eshop/index.php?main_page=product_info&cPath=3&products_id=116
emma
« Reply #5 on: June 15, 2011, 07:14:59 PM »
Hi bob its emma you bought rear tailgate and steel wheels off us, we have some headlights if interested my number is 07810 424130
badboy
« Reply #6 on: June 15, 2011, 08:39:40 PM »
thanks emma for the reply wont delete details this time ::)
the head gasket went on the car the other week (left it running after servicing it and didn't know about the problem of over heating on the water-cooled model) we think the stat has failed (probably due to muck in it as we hadn't got round to flushing cooling system >:(
everyone has suggested we do away with the stat to improve coolant flow?
so it has put us behind on the work but once we had got the lights switch sorted and electrics bad earth we thought that the reflectors might not cast enough pattern for the MOT
now that i know you have some i will wait for results from MOT (we should have the car ready for one in a week or so) i will then get back to you then with what we finally need.
the pipe from the air filter to carb - do you have anything like that as well?
or alternative pancake air filter for the carb or suggestions to by pass the old air filter?
we might even need a carb if we can't getting it running right ::)
ps - how much are your lights and i presume they are good enough to pass a MOT?
bob
