As you might be aware, I have tried a well-named brand amongst 126/500 people with a name that is numerical and had little success.
The problem was the electronics did the advancing of the ignition timing and no matter what I did, it always seemed to over advance the ignition leading to the engine over-heating.
I glanced upon a new set-up on e bay the other day selling for £52, and though I'd give it a go.
One simply removes the points and condenser and plate that holds that all in, and replace it with the new plate, use the existing screws. Then one wire to posative of the coil and one to the minus of the coil and it's ready to go, only thing is, make a note of where the rotor is pointing before you start or you end-up turning the dizy till she fires.
Here is the option I am trying:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350439087489&ssPageName=STRK:MEWAX:ITSo far car has fired-up no problem, runs smooth and does not seem to over-advance as I checked it with a timing light.
For the price, it cannot be bad however as with all things new, carry the bits for your points etc for a while, just in case
