Author Topic: New front spring height  (Read 4817 times)
« on: June 07, 2011, 11:08:19 PM »
Just fitted my cut down springs to the rear looks good, decided to fit the front reverse eye and just finished.  The front is now higher than it used to be, used a spring compressor to flatten it to allow fitment all looked well untill I fitted the wheels and lowered to the ground. I know the old spring was more than likely the original and was horizontal.  Has anyone had this problem? I fitted a front spring to my 500 and it looked ok after atrip round the garden.  Any  ideas on lowering the front?
barkingwilhelmina
Re: New front spring height
« Reply #1 on: June 07, 2011, 11:37:33 PM »
Yeah, I have the same problem at the moment. I fitted a new spring and used a clamp for the job. Now the ride hight is far too high and the nearside front shock is constantly fully extended. When you go over a bump it rattles the extent of the shock. I have looked at previous comments on this topic and it looks like loosening everything off and settling everything on the ground and then re torque the fixings may help. Haven't done this yet though and you may manage it before me, so let me know how you get on....
Where did you get the spring from.....?
Alfons1972
  • sorry for my bad english...
« Reply #2 on: June 08, 2011, 05:33:53 AM »
yes, that's right.
What I have done after ten years of driving with a too high front is, to take the front spring to pieces and cleane it thoroughly from rust and old paint.
The problem (also at new springs !!!) is that rust will make the spring hard because the single springs can't slide on each other... Then take a good water-proof grease to help it slide.
The cleaning and greasing took about one hour and now the front is much lower and softer..
some of our german friends use threaded rods instead of the shock absorbers for mounting the spring. It helps to lower the front (the more you tighten the rods the lower the front gets), then you can fix everythig as barkingwilhelmina said...
Do not forget to check the geometry of the steering after that, it is much important!
« Last Edit: June 08, 2011, 05:35:52 AM by Alfons1972 »
Fiat 500 R
Fiat 500 giardiniera
« Reply #3 on: June 08, 2011, 01:04:59 PM »
I got the spring from a member on this site.  As I said I fitted a front spring to my Gamine and all went well no probems with height, it was the original so this may have be the reason.  I used a clamp system that acts like the original fiat clamp for fitting the spring. The clamp compressed the spring until it was almost flat and fitment was straight forward.  After the spring was bolted in I released the clamp and the spring relaxed into a bit more of a curve.  I had thought the bushes at the end of the springs were not tight enough, they could rotate in the spring, then this may contribute to the increase in height.  When I replaced the bushes they did go in realatively easy. Any thoughts?
barkingwilhelmina
« Reply #4 on: June 08, 2011, 02:17:06 PM »
I used a clamp as well but still... boing! I like the idea of the threaded rods. Loosen everything off remove shocks and wind it near flat. Tighten everything up and leave for a few days to settle. I'm gonna try this. I think it must be something to do with aftermarket springs.....?
« Reply #5 on: June 08, 2011, 10:17:58 PM »
when i have changed my leaf springs i have always used this method, remove old spring and refit new spring into position on mounts, then using a jack i refit the steering to the spring and once this has been done i let the car down and tighten up all the bolts correctly, you must then also adjust the camber on the front as the lower spring will give you a more positive camber and so the tie rods must be adjusted. it could be possible that the tie rods are holding the suspension and giving you an image of no change in height ?
« Reply #6 on: June 09, 2011, 12:42:40 PM »
The gap between the wing and the tyre is approx 75mm, I also used a jack to push the spring end onto the stub axle but when I removed the jack the spring moved down.  I am going to loosen the bolts/nuts get some bags of sand and load the front up and then re-tighten to see if this works.  The wheel are leaning outwards, once I get the heiagt right I will adjust the camber.
« Reply #7 on: June 15, 2011, 12:09:16 AM »
I checked the no of leafs on the new reverse eye and there are 6, the original spring has 5.  I think I will remove one any idea which would be best to remove or does it matter.  I have arranged to have the old spring reversed to see how that looks.  I can bounce on the original spring and it will drop in height by 50%, the new spring wont budge.
Alfons1972
« Reply #8 on: June 15, 2011, 06:14:33 AM »
As I have written above, also a new spring should be dismounted, cleaned and geased. There can be paint and rust between the leaves...
Fiat 500 R
« Reply #9 on: June 15, 2011, 11:49:14 PM »
Hi Ralph,
Just a word of caution, I had my Bis spring reversed, But to do this they have to cut the safety leaf so if for any reason the spring eye gives way or shatters, the whole suspension and steering drops off on that side, Not Good!
If your taking it to a spring manufacturer just have them flatten the spring to lower it.
http://club126uk.co.uk/index.php?ind=gallery&op=foto_show&ida=35
« Reply #10 on: June 16, 2011, 07:57:23 PM »
Hi Pete, took the spring down this morning and they advised against, they were concerned that it would crack when they put it in the oven.  Also found they dont carry the work out here it needs to be sent down south.  I was told that there was no one in scotland that can do this now.  I will try the american way with a jack to re-profile the original and if that works I will do the same to the reverse eye.  Thanks for the heads up. In your photo of the springs the reverse eya is lower than the standard I dont think mine is like that.
« Reply #11 on: June 16, 2011, 08:58:01 PM »
"Down South" you must be talking about those guys grubbing about in the dark satanic mills  ;)
I would show you my spring collection but have got the late summer into autumn styles on the boardwalk at the moment  :$
On a more constructive note some opinions suggest that the standard spring with machined down ally mounting blocks is the best way to go.
After over 100.000 miles the front spring on my car seems to have reacted to gravitational pull  :$
« Reply #12 on: June 27, 2011, 07:02:14 PM »
Hi Rusty, down South just the opposite of up North I think that is just outside London ;D ;D ;D I stripped the original front spring to allow re-profiling.  The nut was welded in place, is this normal? Anyway, with my trusty vice I managed to lower it by 50mm.  All I have to do is put it back together and fit it.  I managed to strip the spring to axle bolt, need to see if I can find one.  Where can I buy the plastic separators, the originals are past their best.
« Reply #13 on: July 11, 2011, 09:44:14 PM »
Well removed the reverse eye and measued it against the reprofiled original about 40mm difference.  Did the wee fat man test and jumped up and down on the springs to see what the difference is.  The original, 5 leafs, moved freely and moved about half way down the reverse eye, 6 leaf, only moved down a quarter.  Looked at the leafs and found the original spring thickness at 3-3.5mm and the new reverse at at least 4mm.  Stripped the new reverse eye to clean and grease up.  Decided to mix and match, removed the top and second, additional, and replace them with the top leaf from the original spring.  Did the wee fat man test and the new revised spring is very similar to the re-profiled original.  Ordered new alloy seats rubber inserts and clamps, hope to fit it all back this weekend if the weather holds.
« Reply #14 on: July 12, 2011, 11:48:26 AM »
ralph you are scottish it should be business as usual even if its peeing down!!
