Hi guys,
I've been trying to find the source of this oil leak since day 1.
The engine side of the flywheel has fresh oil on it, after driving.
No oil on the clutch side or gearbox, only black dust.
I replaced the oil pan and gasket, as a matter of precaution and still the exact same problem.
Considering my oil level goes down every few weeks I would say it's the engine oil and not transmission.
I think it's the crank bearing oil seal behind the flywheel. Does anyone else think this is a good call? And can it be replaced just by removing the flywheel outside or does the crank shaft have to come out?
I have the manual for the car but it seems to skip over replacing this oil seal...
Any help would be greatly appreciated! Thankyou in advance guys,
Alastair
