Thanks Pete! That sounds a plausible explanation. i'll check the exhaust after for a catalyst. well yesterday 31/5/11 i had my first breakdown! as i was approaching traffic lights aswell!! Previous young trainee mechanic owner did something to the back right wheel, maybe brakes, and forgot to put all the four 13mm bolts back into the flexible joint!! Hence no drive in gears, anyway found one bolt snapped off up the road. So i improvised and borrowed one off the left wheel, and borrowed one off the exhaust manifold, and it got me home ok! I need a new flexible joint now. I also tightened up the left flexible joint bolts which were loose! Trainee mechanics!
So, 126 owner friends, check your flexible joints bolts! It's an easy job, leave car in neutral so you can push it to expose bolts while behind and under the car and check them. Regards David
