Author Topic: I bought new wipers and now I'm stupid.  (Read 3104 times)
AlleyNiki
« on: May 30, 2011, 02:11:19 AM »
I wanted to get some of those pretty chrome wipers from www.Axel-Gerstl.de for my right wheel drive 126.
When they arrived I quickly realised my mistake. Those wipers are for a left hand drive vehicle that are positioned on the other side, and therefore need to have a kink the other way!!  :-X DUHHH!
Guess I better stick in them in the vise.. And do more research next time.
Alley.
Re: I bought new wipers and now I'm stupid.
« Reply #1 on: May 30, 2011, 07:28:45 AM »
 :$ I did the same in the past :$
AlleyNiki
« Reply #2 on: May 31, 2011, 09:24:52 AM »
Can they be bent the other way?
« Reply #3 on: June 05, 2011, 10:51:33 PM »
If the arms are riveted into the body, then you should be able to drill them out, swap them over the re-rivet. I done that to a pair I had a few years ago, and they still work.
AlleyNiki
« Reply #4 on: June 06, 2011, 02:47:20 PM »
Not these ones, unfortunately... the arms have a 90 degree bend on the end inside the body and the spring pushes against this. This 90 degree bend prevents them from being slid out. That is without unfolding the metal body..    :(
« Reply #5 on: June 06, 2011, 11:32:23 PM »
Ah, thats a pity!
« Reply #6 on: June 09, 2011, 06:04:32 PM »
Fit Mini ones, that's what I have on mine, cheap off ebay too!
124cso
« Reply #7 on: June 24, 2011, 02:06:22 PM »
Alley.
You'd not be the first to make that mistake. Know a guy bought a fancy exhaust manifold for a Ford out of USA, cost him hundreds plus duty & freight. A shame we have a steering column on the right side of the motor and it would not fit. Strangely when you sit on the other side to steer, it does not seem to be an issue.
