Author Topic: Wheels - help needed  (Read 2584 times)
chug
« on: May 23, 2011, 12:06:37 PM »
Hi everyone
Probably a silly question but, could any of you experts out there help?  There are some wheels on ebay - see link if I've done it properly - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300559946881
Would these fit my 1982 126?  I've just got the bog standard grey wheels on at the moment and would like something abit more classic.
Thanks in anticipation.
Re: Wheels - help needed
« Reply #1 on: May 23, 2011, 02:09:32 PM »
The quick answer is no, those wheels have the much larger PCD bolt holes to suit the early 126 cars and that style were also fitted to the 500R. The 500R wheels were 3.5J and the 126 ones were 4J. You are pretty stuck for choice if you want 126 steel wheels as there was only the 12" design you have then the 13" Bis rims.
Loads of other 98 PCD Fiat , Alfa & Lancia steel rims will fit OK but you are talking 13" or larger so new tyres as well. One advantage however is that you will be able to go for tubeless tyres rather than the 126 tyres with inner tubes.
Then you have the alloy wheels but the classic ones in good nick like Cromadoras tend to fetch big bucks.
« Reply #2 on: May 23, 2011, 03:42:20 PM »
BMW e21 steel wheels are popular in Poland, fitted with wobble bolts (or often with slightly larger holes drilled)
Fiat x19 wheels look nice, normally someone breaking one on Ebay.
« Reply #3 on: May 24, 2011, 10:30:05 PM »
124cso
« Reply #4 on: May 24, 2011, 11:23:22 PM »
Remember that if you go to 13" rims, you will have to fit low profile tyres, probably 60s and if they are too wide, they'll rub on the body when turning.
124cso
« Reply #5 on: May 24, 2011, 11:28:34 PM »
Is this because of the rim design ?(do they leak ?) I have just bought  new Pirelli P3 and see that they are made as a tubeless.
DEYAN IYI
« Reply #6 on: May 25, 2011, 07:41:48 AM »
If you have good rims with no deformations or rust, they will not leak.
« Last Edit: May 25, 2011, 07:47:17 AM by DEYAN IYI »
