Author Topic: picture of spare tyre under bonnet?  (Read 2503 times)
badboy
« on: May 15, 2011, 08:29:50 PM »
should a 126 have a spare up front?
if so pictures please and would a spare be the same size as normal wheels and for that matter what size standard steels should a 1991 water cooled have?
thanks!
Re: picture of spare tyre under bonnet?
« Reply #1 on: May 15, 2011, 08:49:00 PM »
Spare should be up front, yes same size as the rest 13" on Bis
badboy
« Reply #2 on: May 16, 2011, 09:41:12 PM »
any pics of one under the front bonnet and what holds it in place please?
green-fly
« Reply #3 on: May 16, 2011, 11:51:36 PM »
aircooled pic if it helps..assuming bis is the same! cheers,brett
badboy
« Reply #4 on: May 17, 2011, 09:07:49 PM »
does it fasten down with anything for example straps / clips etc as can't see what would keep tyre secure it in position.
bob
Blonde126
« Reply #5 on: May 17, 2011, 10:38:14 PM »
bob
Hi I have an 89 Bis and there's a rubber stretchy strap with a hook-like thing at the end that latches onto the wheel to keep it secure. To be honest, even without the strap the wheel is pretty snug as there is almost a well-type feature that the wheel fits into that stops the wheel from rolling around.
Hope this helps :)
green-fly
« Reply #6 on: May 18, 2011, 12:16:53 PM »
No straps etc on mine (only rubber with hook to hold the jack in place) but sits snugly without moving..what was the prob initially,are you missing your spare?
Dr Moose
« Reply #7 on: May 18, 2011, 12:39:36 PM »
POG (a/c) has a strap, but you shouldn't need to worry as the wheel should sit in the well.
Unleashing the Inner Teenager since 1988 (and now especially in POG!)
badboy
« Reply #8 on: May 19, 2011, 08:12:54 PM »
thanks everyone for reply
no strap or spare in my car so i will have to see if anyone in northwest has any parts i need so will put a post up under wanted ;D
« Reply #9 on: May 21, 2011, 11:20:00 AM »
I bought an original strap from Axel Gerstl for Euro3.28. P&P plus VAT totalled Euro13.8. Here is the link to the strap you need for the Bis. Item no. C09045. This is what it looks like installed.
http://webshop.fiat500126.com/index.php/katalog/artikelinfo/1516-1-spare_tire_mounting_rubber.html
« Last Edit: May 30, 2011, 08:09:03 AM by Amateb8 »
