Author Topic: Halfords deal  (Read 2101 times)
Kipster
Halfords deal
« on: May 15, 2011, 12:02:48 AM »
Just bought 5 litres of semi synthetic 15/40 oil at £19.99 from halfords..
But halfords are throwing in a good set of their professinal screwdrivers free. (list £9.99) so basically your oil is ten quid.  The screw drivers are good quality so i would go for it. This offer is for any halfords oil mind.
Re: Halfords deal
« Reply #1 on: May 15, 2011, 08:51:33 AM »
Many thanks for the tip. I'll attempt to change the oil myself which is going to be a first. A couple of questions please, if I may. I just managed to find the oil plug. Do I need to warm up the engine or can I drain the oil when the engine is cold. How many litres do I need? How do I check whether I have placed enough oil in the engine. How do I dispose of the old engine oil? Sorry, seems like a straight forward task but just need to make sure.
I am bit paranoid. Many years ago, I wanted to impress my father by changing the oil in his Merc whilst he was on a biz trip. I thought, how difficult can that be? Took the oil plug out with the help of my mate, let the oil drain out. Put the plug on, viola! 8) Started to pour the oil in, contantly checking the dip stick. The dip stick was not showing much, so I kept on pouring the oil. The oil actually reached the very top until the oil cap!!!!! I thought it was still okay. To cut the story short, he was not very pleased :cry:.
Re: Halfords deal
« Reply #2 on: May 15, 2011, 01:56:39 PM »
Just been to Halfords to buy the engine oil. My local Halfords is offering in addition to the screwdriver set, are offering free 5m cord and a proper car polisher (mains based) as well with every Halfrords oil purchased.
badboy
Re: Halfords deal
« Reply #3 on: May 15, 2011, 08:38:34 PM »
i will pop there myself tomoz
when i checked at local spares shop about service bits for 126 they said 10/40 mineral oil.
doesn't sound right was thinking of putting semi synthetic magnatec which helps with cold start ups.
what does everyone else use?
Re: Halfords deal
« Reply #4 on: May 15, 2011, 09:14:42 PM »
The official recommendation for the 126 BIS is 15w40 but others have used different grades.
Re: Halfords deal
« Reply #5 on: May 15, 2011, 09:40:48 PM »
The service book shows 10w-40 but that was when it was new. I use 15w-40.
Yes it is a good idea to warm the engine up before draining it. The aircooled needs 2.5l of oil and the centrifugal oil filter needs to be cleaned every 30000kms (so every third oil change). When filling check the dipstick, the level's good if it's nearly at the top (since after starting the engine the level will go down a bit). When it's been filled up with oil let the engine run for a moment before checking the oil level again and top up if necessary. Oil level's good if it's between the top and bottom line (alright if it's near the top level).
124cso
Re: Halfords deal
« Reply #6 on: May 24, 2011, 11:18:19 PM »
I've got a 1977 Haynes manual that says "Castrol GTX" which was and still as 20w50, although in the last few years I have seen a 20/40 GTX at a cheaper price than the 20/50.
Being air cooled, you probably want to pay a bit more for a better quality oil (rather than whatever is today's special at the supermarket) ?
Re: Halfords deal
« Reply #7 on: May 29, 2011, 12:34:23 AM »
I have used Castrol GTX 15w/40 (non-synthetic oil) on my last oil change a year ago. Need to do another oil change this year. There is a semi synthetic version of the aforementioned, which I might try.
