Has anyone suffered from the effects of door warping?
my drivers door has warped and is rubbing on the wing causing paint to come off. (looks horrible) :roll:
ive had the door off, and i believe its because the hinges are intenal to the door, their is play in the bottom hinge this is what i think is causing it. Ive heard this is a common problem with the 126, ive seen it alot myself. So there must be a common soloution to the problem?
will be interesting to know, if anyone else is suffering from same problem
regards
