Author Topic: 5 stroke  (Read 2918 times)
Re: 5 stroke
« Reply #1 on: May 06, 2011, 09:59:27 PM »
Ok, hope i understood it correctly: the centre piston works on the exhaust gases emitted by the other two cylinders?  ??? What's the point of that?
I read in a car mag a while back about a Saab engine which had variable compression ratio. The cylinder head literally moved on the engine block to alter the comp. ratio of the cylinder. It was fitted to a 9-5 i think and was tested by the journalists, though i never heard of the engine used again...
Thought i'd mention this as there are a few weird internal combustion engines that never made it past the prototype stage...
Allan
Re: 5 stroke
« Reply #2 on: May 07, 2011, 04:30:36 AM »
On the same website take a look at the Ducatti V8.
Re: 5 stroke
« Reply #3 on: May 07, 2011, 09:05:39 AM »
if it uses the gases expelled from the cylinders then i suppose it is just like a turbo by that meaning it uses the redundant gases again however it utilises them in a way that does not boost the power as a turbo does? if thats correct then its a bloody cool bit of kit...
Eklipze3k
Re: 5 stroke
« Reply #4 on: May 07, 2011, 09:54:41 AM »
From how I understand it, it'll use 2/3 as much fuel, cylinders 1 and 3 will ignite simultaneously and instead of igniting more fuel to force cylinder 2 to decompress, the exhaust gasses from 1 & 3 will do that instead. Very clever concept, which means we'll never see it in use ...
DEYAN IYI
Re: 5 stroke
« Reply #5 on: May 07, 2011, 04:51:24 PM »
Actually nothing really new. The compound steamers used to have double, triple expansion or even more:
I'd love to see this 5-stroker  in a running car ;D
