Author Topic: vw Liners and Pistons  (Read 2630 times)
« on: April 16, 2011, 12:31:17 AM »
I run a 126 650 with panda head in my fiat gamine and it goes very well the next stage is to further upgrade one of my 126 650cc engines, I have an other panda head and carb but would like to up the cc capacity to 800.  I have heard that fitting VW 1600 liners and pistons is the way to go.  Has anyone done this and if you have what do I have to do to get it all to fit and work.  One of the Polish sites had info but I have been unable to translate to understandable english.  Any info would be appreciated.  I have been offered VW liners and piston kit for £130 new.
Re: vw Liners and Pistons
« Reply #1 on: April 16, 2011, 01:49:40 AM »
I wondered if the the conversion on the 795ccs engine I have made use of VW parts but I have not seen any identification marks. The barrel fins are a different shape and there is a tapped hole about half way up one side of the barrel. May find out more when I strip for a rebuild later this year. The work was done in 1984 and included boring out the crankcase to take the barrels. Another thing that you have to consider is that the gas escape ring groove on the cylinder head face that will now be very close to the bore diameter. On the 126 head that came with my engine the groove had been filled with weld then remachined .
paul555
« Reply #2 on: April 21, 2011, 02:06:53 AM »
Hi. I don't know if you've seen info on that page http://www.126fan.pl/--> dzial techniczny--> maluch 800ccm but there is nearly full description with picks how to fit VW cylinders and pistons to 126. I can have a quick go with translating the basics  ;)
You'll need:
2 complete VW 1600 aircooled pistons 86mm diameter (piston, rings, pin)
2 cylinders from above but must be for shallow head (seems to be two types-it has lower lip on top)
BIS crankshaft (narrower counterweight and factory balanced)
2 piston pin sleeves for Zuk (old polish van so i think you need to find replacement for it)
0,3-0,5mm copper sheet for headgasket
First paragraph:
welding reinforcements on engine block. everything like on pics. but then you need to check if crank shells fits properly and crank turning freely
Second paragraph:
Cylinders. Top lip must be machined out to first fin/rib, slightly flatten rib to make place for head to sit on and make the rib about 10cm diameter to avoid any cracks. Then machine bottom of cylinder to get 79.5cm beetwen top(where head sits) and bottom (where cylinder sits on engine block)
When that's ready grind all fins/ribs to make them fit to engine block. There is possibility that crank counterweight might hit cylinders so you need to check it. If it will grind off equal amount on both cylinders and pistons.
Third:
Connect con rods to pistons. That's where you need some sleeves for pins. You might also lighten and polish con rods.
Fourth:
Head. Gas escape bolt and goove have to be welded up. Combustion chamber have to be widened to about 86mm.
Make head gasket, build it up and of you go ;D
Thats basic translation, if you don't understand anything just ask ;)
« Reply #3 on: April 21, 2011, 01:11:48 PM »
Paul thanks for that I printed off a bable translation of that page and most of it made no sence. I will have a go, only £120 for the liners and pistons, need to source a bis crank though, make a couple of piston pin sleeves, I take it these are for the small ends.
paul555
« Reply #4 on: April 21, 2011, 06:53:31 PM »
It might be small end, not sure how it's called. It's a sleeve/bearing for pin which joins con rod and piston.
Go for it if you have enough time/money ;D Loads of machining involved and I've noticed that cost small fortune over here.
I'm gonna build engine aswell, using stock internals. But first thing though is to get my 126 on road ;) Still quite few bits to do :$
