Author Topic: Gearbox Problems  (Read 3533 times)
gsxr126
Gearbox Problems
« on: April 14, 2011, 09:05:30 AM »
Hi all,
Just put together my gearbox using all new parts. When i put the rear housing on it was moving ok in the neutral position, so I tried sliding it into some gears. I put it in second i think and now it seems to have locked in that gear. Any ideas on what could be wrong?
Any advice is appreciated - especially from the gearbox experts.
Dan
Re: Gearbox Problems
« Reply #1 on: April 14, 2011, 10:30:14 AM »
Are you trying to move the gear linkage shaft by hand (that is not with the gear stick)?
When i had my gearbox on the bench and tried selecting gears it did seem as if it got stuck in some positions but as soon as it was fitted all the gears could be selected fine using the gear stick.
gsxr126
« Reply #2 on: April 14, 2011, 04:00:39 PM »
Thanks GT,
Yes i was trying to move it by hand. I thought that might be the case. Hoping it should be ok once all bolted up. Thanks once again, your a legend - BTW if your planning to come to OZ i'll sell you one of mine for a BB price if you like, but not my 10K klm minter  - be warned though, there's an absolute minimum of spare parts here, my gearbox cost me $1300 to buy/import and my time to assemble it all.
FYI The 31K klm niki on oz ebay ended up going for $3200, the most I've ever seen one go for in oz recently.
Dan
« Reply #3 on: April 16, 2011, 01:04:27 PM »
$3200  :o I guess they are rare there... thinking of getting a Niki, Lada or an old Skoda (105) first as i've mostly done work on those before getting into an Aussie V8 ;D
AlleyNiki
« Reply #4 on: April 17, 2011, 07:53:41 AM »
I guess us Aussies need a 126 spare parts emporium.
Hmm, could be a good venture if I had the funds to start it up!
Alastair
skelz
« Reply #5 on: April 17, 2011, 08:26:33 AM »
given the cheapness (is that a word) of 126 fan it would be hard to match his prices
« Reply #6 on: April 17, 2011, 10:43:29 PM »
If i had large enough pockets i'd fill it all up with spares seeing how hard they're to obtain over there... 126fan is the cheapest i reckon (so are other Polish parts available on allegro, just i don't know polish), but luckily i'll also have friends over here to have them send stuff to me should the need ever arise...
gsxr126
« Reply #7 on: April 18, 2011, 03:24:05 AM »
I think I found the problem, but its still not sorted yet. I had my doubts on the straightness of the gear selector lever in the front casing. It turns out that its bent (bloody scumbag selling me new/poo parts) and wont slide into gears properly. So here we go again - pull it out, replace casing with an old one I have and try again. Thanks for all the advice guys.
« Reply #8 on: April 18, 2011, 07:05:26 AM »
Hi Dan , just back from rubbing shoulders with your Kiwi mates from across the water  :D
I have been following the forum when I could get internet access but did not chip in too much. Anyway I did agree with GTMaster that you need a bit more leverage to check the gear change. I have tended to use a screw driver pushed through the coupling mount hole . Allows you to push / pull & twist as well.
Having rebuilt a few 126 boxes I have a box of used parts if you find you are short of anything  :)
gsxr126
« Reply #9 on: April 18, 2011, 10:14:31 AM »
Thanks Rusty,
I should be right for parts, If you could give me a rundown on how to replace the front casing (just in case i did something wrong) it would be greatly appreciated.
PS: did you slip that blue 500 in your luggage when in NZ?
Dan.
gsxr126
« Reply #10 on: April 22, 2011, 06:38:30 AM »
I replaced the housing and lever with a spare i had and it seems to be fine when in neutral, but when i try to select any gear and it slips into that gear, it gets stuck and wont budge. Loosening the side cover to release tension on the 3 springs and ball bearings allows it to move back into neutral, but when i tightent the side cover back up it does the same thing. Any ideas?
I cant really put it back in until i sort this.
smallcox
« Reply #11 on: April 22, 2011, 08:05:20 PM »
This  plate with the spring and balls is what hold the selector shaft in place when selecting a gear.
If you have no trouble selecting all gears with this plate removed as you mentioned above then as all the above have said this is normal. With the gearbox complete if you select a gear, then go for neutral you have to knock it out off gear with some thing like a screwdriver and it is very tight. Once you have your gear linkage connected the mechanical advantage will be less effort ;)
trust the force
gsxr126
« Reply #12 on: April 24, 2011, 10:54:31 AM »
Thanks Smallcox,
Maybe Yoda doesnt like me. I trusted the force when I initially put it in - turns out the selector lever was bent in the housing,(bloody brand new part too). I have since changed the housing and that seems to have sorted the "stuck in gear" problem.
Now i have a new problem - the adjuster bolts on the side of the gear lever are at full forward and I still cant get 1st & 3rd gears. I'm guessing I may need to move the whole engine/gearbox assembly rearward to get the shifter in the right place. It seems that minute movements in the placing of the running gear have a large effect on where the shifter sits and how it works.
Anyone got any other ideas on how to sort this???
Thanks Dan
« Reply #13 on: April 24, 2011, 08:14:09 PM »
Silly question, Are the gearbox/engine mounts in good condition? I had a similar problem and changing the gearbox mounts sorted it without re-adjusting the gear lever :thumbup
smallcox
« Reply #14 on: April 24, 2011, 08:26:06 PM »
Once you prove the gearbox/engine mounts are sound, there are adjustment on the gearshift to allow you to push it forward/backwards.
 If you undo the two bolts on the r/h/s off the tunnel (M8's )and push the selector mechinisum forward a couple off mm and tightern it again, this may help. :-
