i did this with mine, just out of curiousity, cos i had a new set i was gonna fit. i cut one complete coil out, i found i had to do one coil as if i done half, then it would'nt sit properly in the seat of the suspention arm. when i lowerd it back on the ground the results - i found - were quite good. it sat very nicely - about 20mm i'ld say - not to low to scrub the 155 13s that i have on. i would have left it like that only when i jacked up the car again did i notice a potential mot flaw.... when the arm hangs down after its been jacked up, the springs were loose? not just a little either, but quite alot and i'm sure that would be an mot faliure? so i when back to the original idea of fitting the new ones?
