Author Topic: Sticky Accelorator perhaps?  (Read 1879 times)
kitten75
« on: March 28, 2011, 01:21:23 PM »
Have been getting braver and taking the car out for longer distances and it's been running brilliantly!  Just love driving it so much...was stopped at traffic lights on Saturday when a stag night accosted the car, screaming and shouting and waving at me  I was suitably mortified and a very deep shade of purple!  I then headed off and lo and behold at the next set of lights there they were again - this time one of them asked if they could jump in, so ended up giving some strange bloke a lift 100 yards to the next pub much to the rest of the stag nights enjoyment!
Recently though I've noticed the accelorator seems to 'stick' when depressed a bit further than my usual 20-30 mph limit and the engine revs are pretty loud...does this just need a bit of lubrication or is it my imagination and this could be something entirely different?
also, yesterday I had only driven about 5 miles when i got this god awful burning smell - the temperature gauge hadn't even moved off 'freezing cold' so pulled over, opened the boot but being ignorant to the workings of engines didn't really know what to look for - engine was hot but no smoke or anything?  It's never happened before and it panicked me a bit as just kept remembering the post on here about keeping a fire extinguisher in the car!!  Anyway, it seemed ok but just wondered if this was common?
cheers
Mhairi
Re: Sticky Accelorator perhaps?
« Reply #1 on: March 28, 2011, 01:57:10 PM »
Hi, assuming that a Bis pedal is the same as an aircooled, pull back the carper around the gas pedal and oil it well, they do dry out and stick.
I am sure a BIS person will be along soon.
Remember any car can catch fire, not only a 126 :-)
Eklipze3k
« Reply #2 on: March 28, 2011, 02:00:33 PM »
Recent Vauxhall Corsa's being a good case in point - http://forums.theregister.co.uk/forum/1/2007/08/20/self_combusting_corsas/
« Reply #3 on: March 28, 2011, 06:14:41 PM »
Yes, all it needs is lubrication. You also need to check accelerator pedal return spring as well.
midvillesb
« Reply #4 on: March 28, 2011, 11:03:27 PM »
I had the same sticking accelerator issue with my BIS when I got it - it's a potential fault common to all 126s as the aircooleds have the same pedal arrangement.  Moisture and crud gets into the metal sleeve and eventually it starts to seize.  You might be able to cure it by spraying some WD40 at the pedal end of the sleeve but the best way is to take the whole assembly off (bit of a pain as it involves taking the centre console, carpet and central cover off to disconnect the accelerator cable), then remove the circlip from the end of the shaft which lets you slide it up and down the sleeve a bit to let the lubricant work its way right in (I'm sure there's an inappropriate comment to make at this juncture but I'm well brung up so will resist...)
The short cut is to drill two or three pilot holes in the sleeve and then squirt some oil down those.
Turning to the burning smell, are you sure your coolant is topped up? After 5 miles, the temp gauge should be at or approaching normal temperature but if the coolant is low or you have an air lock, there might be no water reaching the temperature sensor. There is a low coolant warning light connected to a sensor in the expansion tank but the sensor often fails. Just be careful not to overfill it or it will start leaking out of the filler cap when it heats up.
Mike
« Reply #5 on: April 01, 2011, 01:22:22 PM »
Yep it gets full of crud and sticks, ours did it.  Take off the pedal and the pipe that runs across the floor and totally clean it and oil it, no trouble after that!
Have fun!
