Author Topic: Facet pump noisy, Regulator leaky HELP!!  (Read 2202 times)
« on: March 27, 2011, 10:05:30 PM »
Facet pump and Sytec pro-fro regulator fitted, looks very nice BUT!!!
Are the pumps always so noisy until primed? Click Click Click .............
Should there be some sort of seals/washers on the regulator, where the brass fittings fit, mine leaks, not from the hoses as very well clamped.
Any ideas ??????
nrg19uk
Re: Facet pump noisy, Regulator leaky HELP!!
« Reply #1 on: March 27, 2011, 10:31:36 PM »
The clicking is normal until the carb is full but if you have a leak this will take longer, Try fitting some fibre washers see if it helps What harm can it do?
Neil gargaro
« Reply #2 on: March 27, 2011, 11:05:24 PM »
The pumps are noisy if they are mounted solidly to the body mine came with some rubber washers which quietens it down a little, To seal the 2 adapters that screw into the pump you can use PTF plumbers tape, Its a thin tape which you wrap round the threads, Then screw the adapter in with the tape wrapped round the threads This seals the threads and stops leakage.
« Reply #3 on: April 10, 2011, 08:05:28 PM »
Leak's sorted thanks a million. Where do you set the regulator? 2 -2.5 ???
« Reply #4 on: April 10, 2011, 08:44:54 PM »
Try it on 2.5 if you think its sluggish at the top end you can notch it up to 3.0 Most weber carbs run a maximum of 3.5
« Reply #5 on: April 10, 2011, 08:54:16 PM »
Thanks, will try tomorrow.
