Author Topic: Finally got some wheels :)  (Read 3854 times)
Draigflag
  • Got a New Abarth 500 too!
« on: March 26, 2011, 06:34:30 PM »
9 months later i found a set of Cinq wheels on eBay. Missed the bid, but the winner never contacted the seller. So a few emails later, and a 100 mile round trip to Llandudno later and they're mine! What do you think? I think they work perfect with the red paint and black trim on the car. They're not as in good nick as i'd hoped, so i'm thinking of giving them a rub down and paint (in black again) after i've taken off the tyres.
« Last Edit: March 26, 2011, 06:37:23 PM by Draigflag »
Re: Finally got some wheels :)
« Reply #1 on: March 26, 2011, 07:06:30 PM »
Those wheels suite the car, they look good. [-/ Nice lookin' jam jar  :P
« Reply #2 on: March 27, 2011, 05:51:19 PM »
The alloys look great in black. I like the matching red centre caps!
Draigflag
« Reply #3 on: March 27, 2011, 07:35:14 PM »
Thanks.
I know the camber on the rear wheels is "supposed" to be the way it is, but it looks pretty severe on mine! Maybe the alloys just emphasise it a lot. Is there any way of adjusting the camber without shorter springs?
Another thing was that the chap i got the wheels from said i would need longer bolts. I put the standard bolts on and they were ok, not as much going into the hub as the alloys are thicker, but still enough if you ask me!
paul555
« Reply #4 on: March 27, 2011, 07:37:29 PM »
Your car look immaculate and alloys do the job great but need lowering a bit IMO ;D
markymarc
« Reply #5 on: March 28, 2011, 09:08:37 PM »
If you are using "steel wheel" bolts then yes they will be too short.  I found this out with mine not so long ago, you will need wheel bolts suited to alloy wheels as they will be longer (alloy wheels are thicker than steel)
marc
« Reply #6 on: March 28, 2011, 09:40:00 PM »
ive used original bolts on cinq alloys for a few years and they havent fell off yet! and i do not drive like an old woman (no disrespect meant to any old women ) .
Allan
« Reply #7 on: March 29, 2011, 12:38:39 AM »
The normal accepted standard on all bolts is that the amount of thread that is holding whatever should be greater than the thickness of the bolt ie 12mm should have at least 12mm of purchase. However having said that one should be careful particually with wheel bolts that they do not go so far in that they hit the adjusters. One other problem that I have seen on disc brakes is the end of the bolt sticking through the inside of the disc and hub going rusty and then tearing out the threads when removed.
Draigflag
« Reply #8 on: March 29, 2011, 06:40:39 PM »
Thanks for the advice. I will use the standard bolts i think and cheque them weekly to see if they have come loose! I don't use the car much anyway. Just dropped them off at my mates place so he can pop the tyres off and painting can begin  :D
« Reply #9 on: February 04, 2012, 03:50:44 PM »
Hello. I'm not sure whether you still have the Cinquecento alloys on your Bis. Are you still using the standard bolts from your steel rims?
Draigflag
« Reply #10 on: February 05, 2012, 01:53:52 PM »
Hi. Not using these wheels now, failed at painting them twice as i wasn't happy with the finish. But i did try them with the steel bolts from the originals, but i never drove the car with them on.
« Reply #11 on: February 05, 2012, 01:55:52 PM »
this= the schizzle! 8)
« Reply #12 on: February 05, 2012, 03:32:35 PM »
Thanks.
Yeah the camber looks severe on mine with the alloys fitted and I am getting more wear on the outside of the tyre but they have been on for about 3 years and the wear isn't too bad.
Draigflag
« Reply #13 on: February 06, 2012, 06:02:46 PM »
Hmmmm seeing these pics again has made me want to get these wheels painted properly and put back on the car! They do look pretty cool!
What do you think? Any ideas?
nrg19uk
« Reply #14 on: February 06, 2012, 06:57:28 PM »
Get them powder coated 30-50 a wheel  8)
Neil gargaro
