Author Topic: Can't be stock... or is it?  (Read 3828 times)
mcbonio
« on: March 24, 2011, 10:06:07 PM »
Just saw this on youtube...
http://www.youtube.com/watch?v=hVvMlHyiUjI
Now, I thought there were no engine mods for the 703cc engine... this car in the video is apparently a 703cc.. but its going mad fast here.. is this stock you recon?
-Mcb
Re: Can't be stock... or is it?
« Reply #1 on: March 24, 2011, 10:38:24 PM »
Re-bored 650 aircooled engine. Won't be a Bis. I would be very very surprised if it were.
Engines can be bored out to 800cc (VW pistons). Once again, more tuning bits for the aircooled, that is not to say you can't get more from the watercooled, it's just you need to be creative :-)
mcbonio
« Reply #2 on: March 25, 2011, 12:04:37 AM »
What can be done with a watercooled then?
« Reply #3 on: March 25, 2011, 08:12:00 AM »
 You can use it to make tea.  :oops: Sorry.
 One of the options is to use a cylinder head from a two cylinder cinquecento, which were sold in Poland. Apart from that you would need to customise yourself.(exhaust, carb, flywheel...) Depending on your skills. Some of the guys even have superchargers on them.
 On an other note I was wondering if you could you bis pistons in an air cooled engine with bored out barrels. Where can you even buy them? I never seen them for sale.
DEYAN IYI
« Reply #4 on: March 25, 2011, 09:46:19 AM »
 </4 ...  [-/
This 700cc championship got nothing to do with Bis, Cinquecento 700 and so on...
Anyway, if you wanna start your tuning from 30hp and 50Nm, or just run this way, that should be cool for daily driver, you'll need Panda 30 head and carb (or Bis, CC700 carb...), Bis crankshaft (forget about the pooty original one if you work for more than 650cc), then Bis/CC700 pistons, but you cant bore the original cylinders. Here it goes: http://www.126fan.pl/www/zwiek_poj.htm First cut the original cylinder 6mm - the lower side, drill them and put new barrels. Put together and run fast the furious Small Fiat :P
« Reply #5 on: March 25, 2011, 06:59:34 PM »
I doubt you could use pistons from a watercooled in an aircooled, the tolerances are different and the piston material is different too...
mcbonio
« Reply #6 on: March 25, 2011, 09:14:18 PM »
Just saw this...  40bhp 126 engine upgrade.
http://www.fiat500sport.com/engine-assembly/piston-liner-kit-for-up-grading-500-r-126engine-700-cc-40-hp-0253.html
It contains, pistons, piston liner, con rods, camshaft, exhaust, ect..  It's expensive, I reckon I could source those part from Poland for maybe a quarter of that price.. lol.. but It gives a bloody good idea what parts to upgrade to get more out of the 126 engine.!
DEYAN IYI
« Reply #7 on: March 26, 2011, 10:08:40 AM »
GTMaster, the Bis/CC700 pistons aren't the best choice, but for sure they shouldn't be worst than the standard ones. The tolerance we can adjust the way we like for aircooled.
Other thing, I bet that the Nanni pistons mcbonio showed here, are Bis/CC700  ;) and in http://allegro.pl you can buy them almost 10 times cheaper ;) Search for: tÅ‚oki fiat cinquecento 700
mcbonio, it's a good idea without the price and the "funny" carb. Also this kit is to be fitted on standard crankshaft, so another bad idea. The con rods are longer, cos they didn't cut the cylinders, and also longer con rods means more Nm in high rpm. Valves are not more than 36x31mm, but you can use CC700 inlet valve 35mm and the standard exh. 28mm.
The camshaft is from about 290* to 300*, and the cheapest variant is the polish Swiatek #385 - 288* for about 75E.
If you make the things I've described in the previous post and fit that camshaft, with the convenient carb and silencer, you will reach the 40hp. ;D I'm working on such a project :)
Regards!
« Reply #8 on: March 26, 2011, 07:04:53 PM »
40hp sounds good, probably the most that can be gained from this engine with NA tuning. The reason i wouldn't bet on using watercooled pistons is because their material is different, aircooled pistons expand more (i'm not an engineer, anyone else know otherwise or has tried such a setup?)
paul555
« Reply #9 on: March 27, 2011, 08:33:51 PM »
40 bhp from aircooled isn't most ;) anyway if you dont like idea of using watercooled bis/cinque 700 pistons you can use some vw beetle 1600 pistons/rings and cylinders. You'll have roughly 800 cc aswell 8).
Back to cinque 700 pistons. If anyone use them you're better to fit cylinder liners from cinque700 to rebored 650 block/cylinders. reason: if you rebore original 650 cc cylinders to cinque700 pistons, thickness of cylinder liner on the bottom will be too small and it'll be more likely to fail.
DEYAN IYI
« Reply #10 on: March 28, 2011, 09:50:05 PM »
May favorite kit to put over Bis crankshaft...40hp is cool but 50hp out of 740cc sounds better ;D
Dear Santa,...
 :P
124cso
« Reply #11 on: May 21, 2011, 02:09:02 PM »
I saw a 500F, perhaps 15 to 20 years ago that had been modified to Mid engine. Transaxle /box must have been swapped as they had installed a 1608cc twin cam 125 engine behind the front seats.
With 90 hp, I'd pick it would have plenty of life ! Regulations these days would make it a bit difficult.
