Author Topic: A Little Teaser  (Read 1539 times)
A Little Teaser
« on: March 17, 2011, 04:10:59 PM »
Here is a little teaser for you , what do the two items shown in the picture have in common  ???
« Last Edit: March 17, 2011, 04:12:55 PM by Rusty's Uncle »
tuned500
Re: A Little Teaser
« Reply #1 on: March 17, 2011, 06:09:54 PM »
Large bracket is a starter support for a 500, starter at top.
The small bracket fits on end of 126 starter and then bolts to gearbox as a support, often lost but easy enough to buy new now.
Re: A Little Teaser
« Reply #2 on: March 18, 2011, 04:41:44 PM »
Hey well done there my friend , not that much of a teaser then. After the recent forum chat about the starter support bracket which often seems to get "left off" on the 126 engines, sometimes with disasterous consquences, I looked again at the 500 bracket I had seen on eBay being sold by a guy in Greece. Even though there is nothing like it in the Fiat workshop manual & I spoke to a couple of guys that have pretty good knowledge about 500s they had not heard of or seen such a device but I stuck my neck out & went for it. Seems like it is an aftermarket accessory that was made by Ascar, whoever they were, but the package (in Italian) mentions Nuova 500 , "Supporto" & "Antivibrante". So I think that kind of tells the story that it is an additional support for the 500 starter motor, probably designed for engines that were going to be put through more extreme conditions  [-/
tuned500
Re: A Little Teaser
« Reply #3 on: March 18, 2011, 06:21:17 PM »
Well i have seen them before so i cheated i suppose!
I agree the 126 bracket is often left off or never put on and it makes a marked difference to the stability of the starter, expecially as the studs and bolt go in to alloy crankcase and often strip.
I've seen the 500 starter bracket a few times before, often sold by the tuning companies in Italy. When i asked they said they were often used on tuned 500's which obviously keep the standard crankcase, due to the vibrations the starters can work themselves loose, i suppose its quite abit of weight which isnt supported at the other end, and the earlier ones i think were 2 bolt rather then 3.
On a slightly different note, regarding tuning companies though. Ever fancied 3 28imb carbs!! A tuning company called Tinari, http://www.500automotor.com/ They do some pretty fancy stuff and the qulaity seemed quite good aswell. not sure the 3 carbs a good idea, more for show!
