Author Topic: Oil change  (Read 3709 times)
Draigflag
  • Got a New Abarth 500 too!
Oil change
« on: February 15, 2011, 06:00:52 PM »
Biggest 126 newbie here asking what is probably a silly question!  :oops:
Hoping to get mine road worthy in a few weeks after a decade of sleeping in a garage. Obviously i want to change the oil. Mine is a bis model remember!
I understand there is no filter to change?
Is it as simple as a conventional car? Does it have a sump with a plug and is it obvious to see from underneath?
What kind of oil would you recommend grade wise and how many litres will she need?
Ta in advance  [-/
midvillesb
Re: Oil change
« Reply #1 on: February 15, 2011, 06:40:08 PM »
The basic oil change is dead simple - looking at the engine from the rear passenger side corner, the sump plug is the one at the far left corner of the sump (nb it goes in horizontally rather than vertically). Once you've got it off, remember to pull off the dipstick and oil filler cap as this will help the flow. When you're refilling it, watch out as the oil filler is pretty restricted and the new oil will spill out over the top of it if you pour it in too quickly.
There is a centrifugal filter in the engine itself but it's a bit of a bugger to get at because you need to remove the rear panel first and then take off pulley etc - if you do a search on here, there are better explanations by wiser folk than me...
Draigflag
Re: Oil change
« Reply #2 on: February 15, 2011, 09:45:46 PM »
Thanks. Might give the filter a miss then...
Any ideas on grade/litres etc?
midvillesb
Re: Oil change
« Reply #3 on: February 15, 2011, 11:45:30 PM »
The official recommendation for the BIS is 15w40 (eg Castrol GTX) but I've just filled my Bis with Duckhams 20w50 which is what I was using in the air-cooled - some folk reckon that's too thick though.
The total capacity is 2.25 litres.
Draigflag
Re: Oil change
« Reply #4 on: February 16, 2011, 07:53:10 AM »
Thanks again. Very helpful. I am learning fast!
Will pick some oil up from Halfords at the weekend!
Re: Oil change
« Reply #5 on: February 16, 2011, 08:43:20 AM »
I reckon that you would wise to do the filter if it is at all possible. It is not a "rocket science" job , once done you will know that the engine is sqeeky clean inside & you can forget about that particular task for another 24,000 miles  ;)
Draigflag
Re: Oil change
« Reply #6 on: February 16, 2011, 06:38:23 PM »
If i had a paypal account, i could donate, then get the BIS manual. That would help a lot.
But if it's recommended, then i'll do my best! Car has done just under 16,000 from new so probably isn't too bad...
Re: Oil change
« Reply #7 on: February 16, 2011, 08:26:12 PM »
There are other ways to Subscribe. Contact ChrisRLewis Administration for details.
Most 126's and 500's will never have had there centrifugal oil filter cleaned out, allot of owners who rely on taking there car to a garage for servicing and mechanics don't even know where it is, It is a very important part of servicing and if left it can cause problems like low oil pressure and bearing failure [-/
This was mine at 17.000 miles
http://club126uk.co.uk/index.php?pid=1
Draigflag
Re: Oil change
« Reply #8 on: February 17, 2011, 07:28:12 PM »
Thanks, looks like a worthwhile job after seeing that! Is all that crumbly stuff the crap that needs to be cleaned? Shocking.
Shame it's not an easy job, i guess nothing is on these little cars!  :(
Re: Oil change
« Reply #9 on: February 17, 2011, 07:34:29 PM »
 :D Selling the car with a full tank of petrol , full MOT and Tax for £99 is pretty easy  </
Draigflag
Re: Oil change
« Reply #10 on: February 17, 2011, 07:45:17 PM »
Ha, well mine is an "investment" apparently...
They are going up in value it seems. If i hold onto it for another 10 years or so!  :oops:
Re: Oil change
« Reply #11 on: February 21, 2011, 02:15:58 PM »
Pete,
Many thanks. The step-by-step photos were quite helpful. It may be pretty obvious (I'm not an expert), but presume the engine is, after removing the rear panel, supported by the trolley jack.
