Author Topic: 500 exhaust heat shield.  (Read 1639 times)
moo
« on: February 15, 2011, 07:51:08 AM »
Hi, does anybody happen to have a spare exhaust heat shiled for a 500 kicking around?
Cheers,
Moo
Re: 500 exhaust heat shield.
« Reply #1 on: February 15, 2011, 08:31:25 AM »
If you are talking about the shield that fits inside the engine cover you can buy a new one for about £12 but I can tell you now that they are cr*p , made from tin foil coated card and will start to fall apart after a year or two  :oops:
moo
« Reply #2 on: February 15, 2011, 04:54:23 PM »
No, it's not that bit, it's the metal piece of tinwear that bolts onto the bodywork inside the engine bay, and then hangs over the top of the exhaust.
« Reply #3 on: February 17, 2011, 08:29:28 PM »
Oh you mean a bit like this , but this is a chopped down special for a 126 exhaust on a 500  [-/
moo
« Reply #4 on: February 17, 2011, 11:11:12 PM »
 [-/ That's the fella! Does it make a difference if you're running a 126 engine/ exhaust? I thought they were the same dimensions/shape externally ::)
