Author Topic: starting  (Read 1879 times)
massa
starting
« on: February 14, 2011, 08:27:43 PM »
finally got bis taxed and tested not the best starters ive owned is there a routine that works better than others , i pull choke out of a morning turn key doesnt seem to like that, 3 or 4 dabs on throttle gets a reaction fires up and i catch it on the choke eventually were in business anyone got a routine that works ?     thanks lads
Re: starting
« Reply #1 on: February 15, 2011, 10:21:16 AM »
This what i found in BIS manual:
massa
Re: starting
« Reply #2 on: February 15, 2011, 05:36:02 PM »
thanks cant make out to much detail thanks anyway very kind of you
Re: starting
« Reply #3 on: February 15, 2011, 09:20:56 PM »
If you look at the picture of the carb, you can just make out a little arrow at the bottom right hand side this is the idle mixture screw, to adjust it make sure the engine is at operating temperature, slowly screw the idle adjustment screw in until the engine starts to hunt (slows down) then slowly screw out until the engine runs evenly. the arrow in the middle of the carb is to adjust the tick-over speed.
The problems you are having sound as if something is out of adjustment, so check the points are in good condition and set correctly, then check the static timing, check the plug gaps and adjust if necessary, if that doesn't solve the problem there could be some sediment or dirt in the bottom of the carb which may need taking off, cleaning and blowing out with an air line.
One of the best investments and mods you can do is to fit an electric fuel pump, the bis carb sits directly above the carb so when you turn the engine off it evaporates the petrol in the carb which has to be pump up again before it will start, since fitting the electric pump on mine it starts first time, I just wait for the ticking of the pump to stop, which means the carb is full of petrol then pump the gas pedal 3/4 times pull the choke on full and the car starts first time even in temperatures of -15 when we had the freezing weather at Christmas [-/
massa
Re: starting
« Reply #4 on: February 15, 2011, 10:56:44 PM »
thanks thats great who does these electric fuel pumps pete ,
Re: starting
« Reply #5 on: February 15, 2011, 11:51:06 PM »
Try searching on Ebay, Any pump between 3.0 to 4.5 psi would be ideal + 6mm in/out adapters [-/
massa
Re: starting
« Reply #6 on: February 16, 2011, 07:41:07 PM »
thanks again sounds like a good mod pete will do that , found that mixture screw and adjusted as you explained will take her to work see how we go let you know
FluxCo
  • 89 BIS
Re: starting
« Reply #7 on: February 23, 2011, 10:22:31 PM »
just blank off the mechanical fuel pump and run inline after the fuel filter?
about adjusting the points, i ve never done this before, is this one of those feeler guage jobbies?
i just ordered a set of leads for mine, because they were arching like a mini firework display
