Author Topic: newcomer onboard  (Read 1747 times)
foxy
newcomer onboard
« on: January 07, 2011, 10:52:14 PM »
Hi all, brand new to this site and the 126 which i have just bought in need of a fair bit of work but alas i fell in love with the little mite when the garage doors opened for the first time in 10 years,was driven in and left, got a rotten front panel which i need to find. put a battery on and it turns over but will not start yet, put a can of fuel in but it comes out a little dirty. restored a few fiat x19s .  any suggestions to fire it up ,maybe i was to impatient and should get advice 1st, not even sure about the correct fuel?
anyway looking forward to starting over the weekend but would like to here it run before replacing any panels etc
Re: newcomer onboard
« Reply #1 on: January 08, 2011, 12:54:30 PM »
firstly i would drain the fuel tank to get rid of the old fuel then go down the route of checking to see if i have a spark at the plugs if so then check the timing is okay and if it didnt fire up. if you have no spark then work your way back plugs, leads, points and condensor, coil, and wiring towards the battery. another method although may be a bit brutal sometimes is to tow it to get it to fire up i have had to do this on cars that have sat for very long periods in the past.
« Reply #2 on: January 08, 2011, 01:07:37 PM »
Ditto what the "Bisman" says about the spark. If you just want to fire it up then I would bypass the fuel tank for the moment. Take out the air filter and put a decent size jam jar in the space , punch a hole in the lid to take a fuel hose down to the fuel pump . Put clean fuel in jar and give it a go, full choke no throttle. If the car was driven in there & you have a spark then you are in with a chance.  [-/
« Reply #3 on: January 08, 2011, 10:24:51 PM »
If you are new to the 126 Bis, when starting the car, be sure to put the gearshift in neutral, press the clutch down and engage/lift the choke fully. Then turn the ignition BUT do not depress the accelerator pedal. When I bought my first Bis, I could not get the car started, as I was unaware of the car's idiosyncrasies.
