Author Topic: BIS lowering!!  (Read 2673 times)
markymarc
BIS lowering!!
« on: January 04, 2011, 06:21:12 PM »
OK guys!!
I will admit im stumped by the conflicting views on lowering the BIS, please help as to the best method.
I realise the rear can be done by just cutting the springs and hey presto, bobs your uncle etc
But the front seems tricky......
Buy a reverse eye leaf spring? (Some say they don't fit the BIS as designed for the air-cooled model?)
Remove a leaf?
Remove the whole thing and have straightened as a thread i have just read on this forum? (as any good hot rodder would do!!)
Cut down the ali mounts?
I run 13" wheels with 175/50/13 tyres on and would like them to sit tight to the arch, current gap - 70mm front and 50mm rear (between tyre and arch) I am prepared to go to a lower profile on my tyres if needs be?
I would love to go for lowering but would like my mind put at rest from people who have done this and been happy with the results.
Many thanks
marc
Draigflag
  • Got a New Abarth 500 too!
Re: BIS lowering!!
« Reply #1 on: January 04, 2011, 06:28:36 PM »
If you want to splash the cash, there is an Abarth style "lower" leaf and shocks for the front, and lower coilovers for the rear. It's not cheap though. Did i read somewhere that you can get Bilsteins for the 126?
markymarc
Re: BIS lowering!!
« Reply #2 on: January 04, 2011, 07:04:39 PM »
Does that fit the BIS though ??
There is a thread in "tuning and customizing" saying that the front leaf spring doesn't fit the latter air-cooled or BIS !!
Thats why i get confused.com.......i would just like final closure on this subject
HELP ME !!
« Last Edit: January 04, 2011, 07:10:29 PM by markymarc »
Draigflag
Re: BIS lowering!!
« Reply #3 on: January 04, 2011, 07:22:10 PM »
Oh i see. Sorry can't help there. I though the front end was the same as the a/c 126. Don't worry, someone who actually knows about the car will be along soon i'm sure!
Re: BIS lowering!!
« Reply #4 on: January 04, 2011, 07:44:03 PM »
righto here we go . you can cut the springs on the rear and it will obviously lower and you can still use the standard mcpherson damper. on the front you can use the rear mcpherson damper from the aircooled along with a reverse eye leaf spring or a reworked original leaf spring, if you wish to you can shave off 10mm from the alloy leafspring mounts. if you are clever you could fabricate an independant suspension for the front of if your rich you can buy one. you can also have rear shocks made up by a custom suspension manufacturer if you have deep pockets.
Re: BIS lowering!!
« Reply #5 on: January 04, 2011, 08:40:43 PM »
In hinesite I should have gone for flattening the standard spring and not the reverse eye spring on my bis, Steve Smallcox has flattened his spring on his 126 turbo and it works really well as the main bottom leaf is the correct length and gets rid of the positive camber that I experienced by fitting the reverse eye spring as advertised on the performance sites for the 500/126.
This method has been used in Poland and Eastern Europe for many years and is tried and tested, If you feel uneasy doing this job I would try and find out if there is a spring re-manufacturer near to you, and have the original spring flattened professionally ;)
