Fiat 126 Chat
clicking relay
Pages: [
Topic: clicking relay (Read 1783 times)
massa
Member
clicking relay
on:
January 01, 2011, 03:21:37 PM »
anyone out there had a problem with a clicking relay on fusebox when attempting a start up car started up good 15 min later turned key dead as if battery was drained put meter on battery spot on lifted boot up and the furthest relay aft was clicking great i thought got one of them swopped it but no difference pushed of no bother even started on the key till the next time eh any idea lads starter wasnt clicking dont think power getting that far thanks dave
126bis1997
Member
Clicking relay.
Reply #1 on:
January 02, 2011, 12:50:52 PM »
Probably earth problems. Check battery terminals and earth to starter. Or knock a bit the starter with a hammer ,could be starter needs brushes. It happened to me once, found out loose terminals at the battery. Cheers and good luck.
massa
Member
Re: clicking relay
Reply #2 on:
January 02, 2011, 03:52:33 PM »
thanks will check that do you know what the furthest relay at the back governs tar dave
Administrator
Re: clicking relay
Reply #3 on:
January 02, 2011, 06:00:08 PM »
Pete.
il cavallo piccolo
massa
Member
Re: clicking relay
Reply #4 on:
January 03, 2011, 06:30:46 PM »
thanks pete will check tommorow seem to think theres 5 relays maybe not if not horn earth might be worth checking out thanks again dave
Pages: [
Fiat 126 Chat
clicking relay
